I’m working on a quadcopter drone with the pocketBeagle since it should be possible to get high refresh rates with the PRU’s for sensor reading and motor control. However, I ran into a problem while communicating with the ESC (T-Motor F35a-32 bit SLIM 11mm):
I can control motors through /sys/class/pwm…$, but not through PWM code from the PRUCookbook (although the PRU PWM-code will blink an LED).
It is inefficient to execute code on a PRU and call Linux commands through Bash to change PWM duty cycles right?
I see around the internet that ESC with PWM should be at 50 Hz (20 ms period and duty cycle 1 -2 ms), but the ESC documention indicates that you can reach kHz in frequency with input protocols as Dshot, Proshot etc. Is there any way for me to access these communication rates through the PRU’s?
