porting android on beagle board
Hi ,
Do you work out my problems,can you send angstrom building link.
I tried procedure mentioned in http://code.google.com/p/rowboat/wiki/ConfigureAndBuild
Then i got terminal window shown in below.In that procedure i didn’t
use saveenv command In my previous attempt i use it,the result was
same.I got message resetting ,i wait for almost 2 hour but there is
no change in terminal.
OMAP3530-GP ES3.0, CPU-OPP2 L3-165MHz
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision Ax/Bx
Die ID #5ac400030000000004013f8901001001
OMAP3 beagleboard.org #
OMAP3 beagleboard.org # mmc init
mmc1 is available
mmc1 is available
OMAP3 beagleboard.org # setenv bootcmd ‘mmc init;fatload mmc 1
80200000 uImage; bootm 80200000’
Unknown command ‘’ - try ‘help’
OMAP3 beagleboard.org # setenv bootargs ‘mem=128M
androidboot.console=ttyS2 console=tty0 console=ttyS2,115200n8 root=/
dev/mmcblk0p1 rw init=/init rootwait
omapfb.viedo_mode=640x480MR-16@60’
OMAP3 beagleboard.org # reset
resetting …
thanking advance
with regards Ajish Zacharias
ajish zacharias wrote:
  Hi ,
1) stop repeating the same question over and over again, this is not
going to help you, in fact it harms as people get annoyed.
2) we do not work out your problems, but we might offer help :slight_smile:
3) what are you asking about, booting android or building angstrom?
please decide...
4) tried google?
Then i got terminal window shown in below.In that procedure i didn't
there is no point in waiting 2 hours for something to happen. "reset"
most likely means to reset the board, so why not power cycle it and
see what happens...
Sorry for confusing words, i needed know about porting android on beagle board.then i face some problem that i mention below.when i type boot , i got a reply booting from linux .But in hdmi display nothing will be coming t
thanking advance
with regards ajish
