I am new to android. I am sorry if am discussing this in a worng
community.
i am trying to port android on omap3evm,
i have followed the procedure given in http://labs.embinux.org/wiki/index.php/Android_Porting_Guide_to_Beagle_Board
. I added the android specifics in config file and i could build the
kernel. I tried it with the filesys given by embinux team but i failed
and got the error
<4>Warning: unable to open an initial console.
<0>Kernel panic - not syncing: Attempted to kill init!
the bootargs which i used are console=ttyS0,115200n8=noinitrd rw
ip=192.168.1.78 root=/dev/nfs nfsroot=192.168.1.77:/home/vishal/
workdir/filesys,nolock mem=128M video=omap24xxfb:rotation=90 init=/
init
I have few questions,
1.Is my approach right ?
2. If it is right then what could be the problem.
or If the approach is wrong then how should I try ?
Also, chmod -R 777 the whole filesystem. The chmod -R 666 in the
instructions gave me the same error messages you saw. I'm sure
chmoding the entire filesystem is overkill, but it works.
Vishal,
Which kernel you are using? Are you using kernel for omap3evm along
with Android patches? Kernel configuration mentioned on wiki page, is
for beagle board.
I get the android robot on the screen but after that nothing happens. when I checked the log i see that dalvik-cahce/ elements are not getting created.
I have put the logs here
I have some errors.
init: cannot open '/initlogo.rle'
init: cannot find '/system/bin/playmp3', disabling 'bootsound'
sh: can't access tty; job control turned off
# warning: `rild' uses 32-bit capabilities (legacy support in use)
Does anyone know the problem?
My bootargsis: setenv bootargs console=ttyS2,115200n8 noinitrd root=/
de
v/mmcblk0p2 vidio=omapfb:mode:1280x720@50 init=/init rootfstype=ext3
rw rootdela
y=1 nohz=off
BTW, is the S-video support the TV?
After reading the FileSystem from SD card, what it will happen next?
sorry for such silly question..
Hi, I am new with Linux so I have this question:
When I do compile kernel with Android patches where should I start in the terminal? Which kernel version I should use? and when I compile with
make ARC=arm CROSS_COMPILE=PATH_TO_CODE_SOURCERY_TOOL_CHAIN uImage
I have PATH = $HOME//CodeSourcery/Sourcery_G++_Lite/bin
then I got: make: *** No rule to make target ‘uImage’.
You can use kernel from embinux site, you should use kernel version is 2.6.27.
Could you please tell me what I should do?
Are you following steps from embinux wiki page ? You should not get this error if you are following it.
------> Please see "linux-omap-2.6-historic.git". Is it correct ?
This creates linux-omap-2.6-historic and not "linux-
omap-2.6" as written in porting guide ..
so is the URL correct ?
------> Please see “linux-omap-2.6-historic.git”. Is it correct ?
This creates linux-omap-2.6-historic and not “linux-
omap-2.6” as written in porting guide …
i am using CodeSourcery Sourcery G++ Lite 2007q3-51) 4.2.1
My make command looks like this :
make ARCH=arm CROSS_COMPILE=/home/test/arm2007-q3/arm-2007q3/bin/arm-
none-linux-gnueabi- uImage
is the error linked to HOSTCC , than the Cross compile toolchain by
any chance?
I am just guessing ?
my HOSTCC is gcc (GCC) 4.2.4 (Ubuntu 4.2.4-1ubuntu3)
I am following the steps to build the android now..
I could apply patches for Tls and Gl Wrapper, but I am stuck when
applying alsa_sound patch.
On giving this command : "patch -p1 < ~/Alsa_sound-v1.1.patch"
I get the following :
Reversed (or previously applied) patch detected! Assume -R? [n]
I gave [n], and asked to apply the patch anyway..
Then it stops like this:
Hunk #1 FAILED at 30.
Hunk #2 FAILED at 106.
Hunk #3 FAILED at 187.
Hunk #4 FAILED at 218.
Hunk #5 succeeded at 985 with fuzz 1 (offset 70 lines).
Hunk #6 succeeded at 1071 with fuzz 1 (offset 77 lines).
4 out of 6 hunks FAILED -- saving rejects to file
AudioHardwareALSA.cpp.rej
patching file AudioHardwareALSA.h
Reversed (or previously applied) patch detected! Assume -R? [n] n
Apply anyway? [n] y
Hunk #1 FAILED at 22.
Hunk #2 FAILED at 157.
Hunk #3 FAILED at 213.
3 out of 3 hunks FAILED -- saving rejects to file
AudioHardwareALSA.h.rej
can't find file to patch at input line 253
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
