Hi all.
I have been trying to find a way to put my BBB into a suspend or sleep state. I found out that power management was not incorporated into the 3.8 kernel, however several posts suggested that it would be working in later kernel (3.14+). I have installed several versions of 3.14 through 3.18 and still have not been able to find one that will allow me to enter a suspend mode.
On some versions I could issue “echo ‘mem’ > /sys/power/state” and nothing would happen. On 3.18 with Debian, I receive “Permission denied”. I’ve seen a few posts about recompiling firmware from TI with custom cape configurations. Unfortunately this is a bit over my head at the moment.
I was hoping someone had some experience with this and could provide a step-by-step for how to get it working. If we could make this more straightforward for the BBB community, I think we would see an increase in the number of people using BBBs for battery-powered applications.
Thanks in advance!
Well, this is a feature that is currently "only" in the 3.14.x-ti kernel:
sudo apt-get update
sudo apt-get install linux-image-3.14.26-ti-r44
sudo reboot
Based on patch status, it "should" enter mainline during v3.20-rcX (so
the next kernel merge cycle)
Mr. Nelson, thank you very much for clearing that up for me. I will try that today.
Quick question…I see that you’re suggesting that I use apt-get to install the kernel, but I don’t seem to have a repository with knowledge of that kernel.
Should I be using git instead?
Thanks.
OK, I found your apt repository. I got that set up and the installation seemed successful, but upon reboot I’m still running my original 3.18 according to uname -a.
Any thoughts?
Sorry, it's not that simple on the older rootfs.. it only works with
rootfs from around Sep 2014 and later..
You have to manually update /boot/uboot/* with the files that are now
under: /boot/
I’m trying to suspend/resume my BBB based on GPIO input. I’m using Kernel 3.14.29-ti-r46 and suspending with “echo mem > /sys/power/state” works. I can also wake up the BBB via the serial console. From what I found on the internet it should be possible to wake the BBB also from GPIO0, but a level change on GPIO0_x (I tried 7 and 26) doesn’t show any effect.
Does anybody know what I need to configure to wake up the BBB from GPIO?
Regards
Axel
I am trying to install that kernel and have not found the repository. Could you tell me where it is?
I though I’d found and added it. My /etc/apt/sources.list is currently:
deb Index of /ubuntu-ports trusty main universe multiverse
deb-src Index of /ubuntu-ports trusty main universe multiverse
deb Index of /ubuntu-ports trusty-updates main universe multiverse
deb-src Index of /ubuntu-ports trusty-updates main universe multiverse
deb [arch=armhf] Index of /debian wheezy main
#deb-src [arch=armhf] Index of /debian wheezy main
but this gives me:
E: Unable to locate package linux-image-3.14.26-ti-r44
E: Couldn’t find any package by regex ‘linux-image-3.14.26-ti-r44’
So I’m wondering if I installed the wrong repository or if it just got broken
as part of the EOLing.
michael
seemed successful, but upon reboot I'm still running my original 3.18
I though I'd found and added it. My /etc/apt/sources.list is currently:
multiverse
multiverse
multiverse
Umm... trusty is available..
deb [arch=armhf] Index of /ubuntu trusty main
#deb-src [arch=armhf] Index of /ubuntu trusty main
but this gives me:
E: Couldn't find any package by regex 'linux-image-3.14.26-ti-r44'
So I'm wondering if I installed the wrong repository or if it just got
broken
It's a space issue with weekly kernel image updates, i only keep "10"
kernel release per channel.. So today use:
sudo apt-get update ; sudo apt-get install linux-image-3.14.39-ti-r61
; sudo reboot
