Power management, turning stuff off..
I am attempting to reduce overall power consumption on the Beagle.
I am using the 2.6.39-pm kernel.
Here is my system as it stands now:
# cat /debug/pm_debug/count
usbhost_pwrdm (ON),OFF:0,RET:3,INA:1,ON:5,RET-LOGIC-OFF:0,RET-MEMBANK1-
OFF:0
sgx_pwrdm (OFF),OFF:1,RET:0,INA:0,ON:1,RET-LOGIC-OFF:0,RET-MEMBANK1-
OFF:0
per_pwrdm (ON),OFF:0,RET:3,INA:0,ON:4,RET-LOGIC-OFF:0,RET-MEMBANK1-OFF:
0
dss_pwrdm (ON),OFF:0,RET:3,INA:0,ON:4,RET-LOGIC-OFF:0,RET-MEMBANK1-OFF:
0
cam_pwrdm (RET),OFF:0,RET:2,INA:0,ON:2,RET-LOGIC-OFF:0,RET-MEMBANK1-
OFF:0
core_pwrdm (ON),OFF:0,RET:0,INA:0,ON:1,RET-LOGIC-OFF:0,RET-MEMBANK1-
OFF:0,RET-MEMBANK2-OFF:0
neon_pwrdm (ON),OFF:0,RET:3,INA:0,ON:4,RET-LOGIC-OFF:0
mpu_pwrdm (ON),OFF:0,RET:3,INA:0,ON:4,RET-LOGIC-OFF:0,RET-MEMBANK1-OFF:
0
iva2_pwrdm (RET),OFF:0,RET:1,INA:0,ON:1,RET-LOGIC-OFF:0,RET-MEMBANK1-
OFF:0,RET-MEMBANK2-OFF:0,RET-MEMBANK3-OFF:0,RET-MEMBANK4-OFF:0
per_clkdm->per_pwrdm (20)
usbhost_clkdm->usbhost_pwrdm (3)
cam_clkdm->cam_pwrdm (0)
dss_clkdm->dss_pwrdm (1)
core_l4_clkdm->core_pwrdm (23)
core_l3_clkdm->core_pwrdm (4)
d2d_clkdm->core_pwrdm (0)
sgx_clkdm->sgx_pwrdm (0)
iva2_clkdm->iva2_pwrdm (0)
neon_clkdm->neon_pwrdm (0)
mpu_clkdm->mpu_pwrdm (0)
prm_clkdm->wkup_pwrdm (0)
cm_clkdm->core_pwrdm (0)
I was wondering if it is possible or even beneficial to turn off:
dss_pwrdm
neon_pwrdm
mpu_pwrdm
I don't use dss.. and have removed the code from the kernel board
file.
Is this using power?
How do I set it to off?
I also will not be using the MPU or NEON systems.
My goal is to knock off another 100mA.
Any other tips or additional things I can look at to further reduce
power?
CJ
You won't be using the ARM?!?!?
Hi Koen,
Mmm .. maybe I will need that.
Is everything I said ridiculous? or is this the concept of 'turning
stuff off' a path I could pursue..
Cheers,
CJ
:smiley: there are toooo many 2.6.39-pm kernels :wink: which branches are you using?
OFF:0
OFF:0
0
0
OFF:0
0
dss_pwrdm
neon_pwrdm
mpu_pwrdm
file.
you'd need MPU as you already heard..
tried setting CONFIG_OMAP_RESET_CLOCKS=y? removed the display drivers? "#CONFIG_OMAP2_DSS is not set"?
power?
aah the black art of power management :wink: I think you should start on linux-omap mailing list :slight_smile:
How does echo "mem">/sys/power/state look like?
Indeed! Which one you use matters a lot.
file.
Good suggestions,
power?
For some sample results on another OMAP3 board (Overo):
http://sakoman.com/OMAP/an-overiew-of-omap3-power-management-with-2639-pm.html
That was done using the stock omap2plus_defconfig (with a few
additions noted in the article). I plan to do another article showing
the effects of turning off various subsystems (like DSS)
Steve
Hi Nishanth
> Hi,
I am using the latest from:
http://sakoman.com/cgi-bin/gitweb.cgi?p=linux-omap-2.6.git;a=shortlog;h=refs/heads/omap-2.6.39-pm
Is this the best option?
> file.
Already in place - but thanks very much for the tip!
> power?
Thanks again for the tips, will see if I can shine some light in
there :wink:
Works well. Would still like to squeeze a bit more off.
Have about 140mA at present in this state.
Will let you know how I go.
Cheers,
CJ
Hi Steve,
>> power?
That has been very helpful!
Will look forward to it!!
Many thanks!
CJ
CJNZ, can you tell me how you built the omap-2.6.39-pm kernel?
Thanks.
Grab it with git and build using the omap2 def config.
I think I had to tweak it a bit for my board which is not exactly like
the BeagleXM but pretty close.
I can't find the defconfig you mentioned anywhere in the git
repository.
Thanks.
I think it is here:
arch/arm/configs/omap2plus_defconfig
