Powering using SYS_5V
I am trying to power my BBB from an external 12V source.
I convert it to 5V using D15V35F5S3 step down convertor from Pololu.
When I connect it to SYS_5V it works but I have to always hit the power button before the lights go on.
Do you know any way to not to have to hit the POWER button ?
Thank you very much.
You could add a toggle switch between the power supply and the BBB, or more simply just not power the BBB down. Leave it up.
Chad
Thanks for your reponse.
I meant that after the power is beeing supplied to the BBB. I have to hit the POWER button in order to make it start.
I did not have to do this when it was powered from sector.
You need to put an oscilloscope on the 5 Volt output from the Pololu.
There is a rise time specification on the start-up Voltage rise time.
I think it needs to reach 5.0 Volts in less than 50 milliseconds.
Read the System Reference Manual
The Voltage can not overshoot more than a few tenths of a Volt.
The operating Voltage should be 5.0 Volts plus or minus 0.25 Volts.
If it overshoots or undershoots above 5.5 or below 4.5 for even a millisecond,
the PMIC will shut down.
A properly designed 12 Volt to 5 Volt converter will work fine, every time.
— Graham
