Preconfigured Ubuntu image with DSP support
It has been quite a while since I played around with the beagle-xm and did some DSP coding.
So I went ahead and used the trusty 14.04 image from http://elinux.org/BeagleBoardUbuntu, running 3.18.1-armv7-x2 as current kernel.
Trying to avoid any pitfalls, how should I proceed from here?
  1. Is there any support for the DSP integrated into that kernel, or is it required to use a special kernel?
  2. Is there any tested/preferred method to get it to work, if not?
Any help is appreciated.
There is no support for DSP on the DM3730 after Linux Kernel V3.4. TI have added support for DSP after V3.4 on the OMAPL138, OMAP5, AM572x (Beagleboard-x15) and a few others I don’t recall. To support DSP on DM3730 on the latest kernel, you need to add support for RPMSG/RemoteProc on the DM3730.
John
