3 B3s all same rev all running 4.1.0-bone9 configured identically to boot via TFTP/NFS (not all at the same time I hasten to add). 1 machine works perfectly. The other 2 both reach the same point then hang. Any thoughts?
TAIA
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.0-bone9 (jevans@acermint) (gcc version 4.9.3 20141031 (prerelease) (Linaro GCC 2014.11) ) #1 Wed Jul 1 13:31:10 BST 2015
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] Machine model: TI AM335x BeagleBone Black
[ 0.000000] cma: Reserved 16 MiB at 0x9f000000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.0 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/nfs rw rootfstype=ext4 rootwait fixrtc nfsroot=192.168.1.110:/home/bone/rootfs,vers=3 ip=192.168.1.11:192.168.1.110:192.168.1.254:255.255.255.0::eth0:off
xxx--------elided-------------xxx
[ OK ] Started Trigger Flushing of Journal to Persistent Storage.
[ OK ] Started LSB: Tune IDE hard disks.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization…
Starting Update UTMP about System Boot/Shutdown…
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Found device /dev/ttyO0.
[ 12.709682] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 12.966802] tda998x 0-0070: found TDA19988
[ 12.997206] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 13.004323] [drm] No driver support for vblank timestamp query.
[ 13.070366] tilcdc 4830e000.lcdc: No connectors reported connected with modes
[ 13.134136] [drm] Cannot find any crtc or sizes - going 1024x768
[ 13.214789] Console: switching to colour frame buffer device 128x48
[ 13.227549] tilcdc 4830e000.lcdc: fb0: frame buffer device
[ 13.233424] tilcdc 4830e000.lcdc: registered panic notifier
[ 13.339779] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 13.376166] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 13.432581] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ ***] A start job is running for LSB: Raise network interf…28s / no limit)[ 44.972386] nfs: server 192.168.1.110 not responding, still trying
