I recently started working on baglebone. I followed the steps on
http://processors.wiki.ti.com/index.php/TI-Android-JB-4.2.2-DevKit-4.1.1_UserGuide
http://processors.wiki.ti.com/index.php/BeagleBone-Android-DevKit_Guide#Hardware_setup
After establishing serial communication the window starts “cccc” as recommended. As instructed I insert the bootable sdmmc card into the beaglebone. Android starts booting and in the end the log stops… snippet of the log is as below. Now i dont know what i have to do. Please provide some support regarding it. I am using ubantu 11.10 using VMware on windows7 64bit
log…
root@android:/ # [ 3.365753] android_work: sent uevent USB_STATE=CONNECTED
[ 3.371520] android_work: sent uevent USB_STATE=DISCONNECTED
[ 3.379119] Disabling lock debugging due to kernel taint
[ 3.435455] android_work: sent uevent USB_STATE=CONNECTED
[ 3.784362] warning: `rild’ uses 32-bit capabilities (legacy support in use)
[ 3.845520] android_work: sent uevent USB_STATE=DISCONNECTED
[ 3.890869] android_work: did not send uevent (0 0 (null))
[ 3.955291] android_work: sent uevent USB_STATE=CONNECTED
[ 4.109863] android_work: sent uevent USB_STATE=DISCONNECTED
[ 4.141540] android_work: sent uevent USB_STATE=CONNECTED
[ 4.147369] android_work: sent uevent USB_STATE=DISCONNECTED
[ 4.211578] android_work: sent uevent USB_STATE=CONNECTED
[ 4.377655] gadget: high-speed config #1: android
[ 4.397521] android_work: sent uevent USB_STATE=CONFIGURED
[ 20.203216] request_suspend_state: wakeup (3->0) at 20170814787 (2000-01-01 00:23:56.3389)
[ 21.057922] net eth0: CPSW phy found : id is : 0x7c0f1
[ 21.064208] PHY 0:01 not found
[ 21.076110] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 21.768341] acc_open
[ 21.773101] acc_release
[ 25.053070] PHY: 0:00 - Link is Up - 100/Full
[ 25.069183] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 33.759277] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
