problem during beagle bootup...
Hi All,
When i try to boot the 2.6.30 beagle kernel image uImage on Beagle
board, I am getting some errors. following are the logs or the same:
   Waiting 4sec before mounting root device...
   Root-NFS: No NFS server available, giving up.
   VFS: Unable to mount root fs via NFS, trying floppy.
   VFS: Cannot open root device "mmcblk0p2" or unknown-block(2,0)
   Please append a correct "root=" boot option; here are the available
partitions:
   Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-
block(2,0)
But when i boot with 2.6.29 beagle kernel image uImage, i don't find
these problems. & the logs for the saem are:
   mmc0: new high speed SD card at address 0002
   mmcblk0: mmc0:0002 00000 974 MiB
   mmcblk0: p1 p2
   kjournald starting. Commit interval 5 seconds
   EXT3 FS on mmcblk0p2, internal journal
   EXT3-fs: mounted filesystem with ordered data mode.
   VFS: Mounted root (ext3 filesystem) on device 179:2.
   Freeing init memory: 140K
   Warning: unable to open an initial console.
   init: cannot open '/initlogo.rle'
   init: cannot find '/system/bin/playmp3', disabling 'bootsound'
   sh: can't access tty; job control turned off
   # warning: `rild' uses 32-bit capabilities (legacy support in use)
Looks like problem with MMC Driver. Can you see the log for MMC
failures or such things ?
Khasim
there are no MMC related failures. please find the logs attached
below:
Texas Instruments X-Loader 1.41
Starting OS Bootloader...
U-Boot 1.3.3 (Jul 10 2008 - 16:33:09)
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
OMAP3 Beagle Board + LPDDR/NAND
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Audio Tone on Speakers ... complete
Hit any key to stop autoboot: 3 ### 2 ### 1 ### 0
reading uImage
1799860 bytes read
## Booting kernel from Legacy Image at 80800000 ...
   Image Name: Linux-2.6.30-omap1-gb82f29c
   Data Size: 1799796 Bytes = 1.7 MB
   Load Address: 80008000
   Entry Point: 80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux.................................................................................................................
done, booting the kernel.
Linux version 2.6.30-omap1-gb82f29c (shrini@shrini-desktop) (gcc
version 4.2.3 (SQL Star ARM Cross Toolchain 2008-beta1)) #2 Fri Jul 3
17:59:11 IST 2009
CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=10c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: OMAP3 Beagle Board
Memory policy: ECC disabled, Data cache writeback
OMAP3430 ES3.0
SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
Built 1 zonelists in Zone order, mobility grouping on. Total pages:
32512
Kernel command line: console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw
rootdelay=4 mem=128M ip=none init=/system/bin/sh
NR_IRQS:402
Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
Reprogramming SDRC clock to 332000000 Hz
GPMC revision 5.0
IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP34xx GPIO hardware version 2.5
PID hash table entries: 512 (order: 9, 2048 bytes)
OMAP clockevent source: GPTIMER12 at 32768 Hz
Console: colour dummy device 80x30
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 126136KB available (3100K code, 289K data, 116K init, 0K
highmem)
Calibrating delay loop... 483.16 BogoMIPS (lpj=1888256)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 520 bytes
NET: Registered protocol family 16
Found NAND on CS0
Registering NAND on CS0
OMAP DMA hardware revision 4.0
bio: create slab <bio-0> at 0
i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368..375
twl4030: power (irq 373) chaining IRQs 376..383
twl4030: gpio (irq 368) chaining IRQs 384..401
i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
musb_hdrc: version 6.0, musb-dma, host, debug=0
musb_hdrc: USB Host mode controller at d80ab000 using DMA, IRQ 92
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
ashmem: initialized
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 246
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
omapfb: configured for panel omap3beagle
omapfb: DISPC version 3.0 initialized
Console: switching to colour frame buffer device 128x48
omapfb: Framebuffer initialized. Total vram 1572864 planes 1
omapfb: Pixclock 48000 kHz hfreq 44.7 kHz vfreq 57.7 Hz
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
console [ttyS2] enabled
brd: module loaded
loop: module loaded
i2c /dev entries driver
Driver 'sd' needs updating - please use bus_type methods
usbmon: debugfs is not available
twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as rtc0
twl4030_rtc twl4030_rtc: Power up reset detected.
twl4030_rtc twl4030_rtc: Enabling TWL4030-RTC.
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
Power Management for TI OMAP3.
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev
1
twl4030_rtc twl4030_rtc: setting system clock to 2000-01-01 00:00:00
UTC (946684800)
partitions:
block(2,0)
below:
With the same image can you mount Ramdisk and then on Ramdisk prompt
try mounting MMC/SD. To confirm you have MMC/SD working and proper
partition naming for blk0p2.
Are you trying NFS ? From Bootargs it is MMC boot.
Khasim
From dmesg info, it seems mmc driver is not compiled into kernel,
please make sure
you have enabaled mmc in kernel config.
Hi Ming Lei,
can you please let me know what are the flags associated with the MMC
drivers. I think I should enable some flags to compile these MMC
drivers.
shrinivas
I get the same issue.have you solved it ?
