Hi All,
I have followed up "narcissus" procedure from Angstrom online
image builder and selected all packages from extended package with X11
and I also get Totem Media Player.
When first time I boot kernel and login to root and apply
totem command it gives me following error.
"GStreamer-WARNING **: Failed to load plugin '/usr/lib/
gstreamer-0.10/libgstsubparse.so': /usr/lib/gstreamer-0.10/
libgstsubparse.so: und efined symbol: parse_sami"
Then I removed libgstsubparse.so library and try to run
totem.Then WARNING has been removed. After that I tries to run totem,
but it gives me following warning.
"Cannot open display: Run 'totem --help' to see a full list
of available command line options."
After that I set DISPLAY environment variable as followed.
$DISPLAY=:0
$export DISPLAY
Then I run
$totem
Display of totem player comes on screen.
Here i have not attached keyboard or mouse with beagle board.
Now i just quit from totem process by ctrl + c. Now again i try to
run totem but didn't get toptem display on screen, instead it
immediately come to shell prompt.
Anyone is having solution for it. To get Totem display again i
need to boot board and again set DISPLAY env.
With Best Regards,
Saurabh
