Problem for S-Video Test of BeagleBoard
Hi all,
when I am conducting S-Video test for BeagleBoard at that time
mount -t vfat /dev/mmcblk0p1 /mnt/mmc/cd /mnt/mmc/
cd mnt/mmc/
these two commands are working fine but when I am giving
echo ‘tv’ > /sys/class/display_control/omap_disp_control/video1
this command is failing,and it is showing
-/bin/sh: cannot create /sys/class/: Is a directory
The I have checked cd /sys/class and find that inside class directory no
display_control directory is there instead of one empty directory is there named
display
[root@beagleboard mmc]# cd /sys
[root@beagleboard /sys]# ls
block class firmware kernel power
bus devices fs module
[root@beagleboard /sys]# cd class
[root@beagleboard class]# ls
bdi i2c-adapter misc scsi_disk usb_endpoint
bluetooth i2c-dev mmc_host scsi_host usb_host
display ieee80211 mtd sound vc
firmware input net spi_master vtconsole
graphics leds rtc tty
hwmon mem scsi_device usb_device
[root@beagleboard class]# cd display
[root@beagleboard display]# ls
So, How I will fix this problem?? Can anyone help me about this??
Thanks & Regards
Anirban Roy Choudhury
This message (including any attachment) is confidential and may be legally privileged. Access to this message by anyone other than the intended recipient(s) listed above is unauthorized. If you are not the intended recipient you are hereby notified that any disclosure, copying, or distribution of the message, or any action taken or omission of action by you in reliance upon it, is prohibited and may be unlawful. Please immediately notify the sender by reply e-mail and permanently delete all copies of the message if you have received this message in error.
Anirban Roy Choudhury said the following on 09/25/2008 05:51 AM:
echo 'tv' > /sys/class/display_control/omap_disp_control/video1
Using the [1] [2] [3] MLO, U-Boot and uImage, with the ramfs ( I
gzipped, then mounted it using mount -o loop rd-file test_fs; then I
copied the contents to mmc filesystem on partition 2. With this I have
been able to get s-video working. the approximate steps are in [4].
there named
display
it would be nice if you kept the old thread alive.. keeps the context
intact.
Most of us spend personal spare time to do things and help around :slight_smile:
Apologies if we have not been fast enough.. you could probably pop into
the IRC chat room as pointed to by [5] - most of us hang around there..
Thanks & Regards
message in error.
Mostly we are nice, however, the above copyright is specifically frowned
upon when you email an opensource community!! See [6]. In general this
list is not hysterical about copyright notices and html mails.. but, it
would be nice to save a bit of internet bandwidth for all of us.. (one
of those nice to haves..)
Nishanth Menon
[1] http://beagleboard.googlecode.com/files/MLO
[2] http://beagleboard.googlecode.com/files/uImage
[3] http://beagleboard.googlecode.com/files/u-boot.bin
[4] Nishanth' tech rambles: How to make a bootable MMC card on Linux for BeagleBoard (using gparted)
[5] http://beagleboard.org/chat
[6] List of Stupid Email Disclaimers
Hi Nishanth Menon,
No actually yesterday I have sent the logs of the output, but don’t get reply so i thought
you may be busy for different work. Then please tell me how the problem will be fixed.
And I cant Access that live chat from here
Thanks & Regards
