I am trying to install preinstalled Destop image of Ubuntu-12.04 on BeagleBoard C3 for my Project work as mentioned on the following site
https://wiki.ubuntu.com/ARM/OmapDesktopInstall#OMAP3.
I have formatted the SD card, It has two partions containing boot files and root filesystem respectively.
When I plugged the card in to given slot and switched power on and kept the user button pressed I am getting
the output show in the image file attached.
There are few lines which seems to be an error to me what do they mean? Lines are as follows
- Unrecognized expansion board: 0
- Wrong Image format for “source” command
What should I do to avoid these errors?
Thank you
