Problem loading Angstrom Demo onto Beagleboard
Having problems loading Angstrom Demo onto Beagleboard. Here are the
steps I've taken so far...
-formatted SD card as described in http://code.google.com/p/beagleboard/wiki/LinuxBootDiskFormat
- downloaded all Angstrom Demo files
-untared Angstrom Demo files onto ext3 Partition as described in
http://code.google.com/p/beagleboard/wiki/HowToGetAngstromRunning
- unmounted the card, put it into the Beagleboard powered by 500 mA
supply using a Pico Projector as the display via the hdmi port
The screen just flickers and does not give a prompt as the Angstrom
Demo site says it should.
Any help would be greatly appreciated!
Kelsey
Try this:
After you extract the tar to ext3 partition.
Use terminal and WGET (if on linux) to get the MLO on your FAT
partition.
cd /media/boot
   wget http://www.angstrom-distribution.org/demo/beagleboard/MLO
   wget http://www.angstrom-distribution.org/demo/beagleboard/u-boot.bin
   wget http://www.angstrom-distribution.org/demo/beagleboard/uImage-2.6.29-r47-beagleboard.bin
Rename uImage-2.6.29 to uImage.
Kelsey,
You should also try using a power supply that is rated about 2.5 A. I think 500 mA might be too low.
Jake
i have a similar problem…
Mine is a clone to beagleboard , EMA-DEV 3530.
i built MLO, Uimage, U-boot.bin for that Board…
But built Angstrom-x11 roootfs For omap3evm.
Even i dont see anything on the touch screen, just a backlight.
What should i do?
Thankyou
Follow this link carefully and you will get the correct output :
http://www.ibm.com/developerworks/linux/library/l-beagleboard-xm/
Then I have used other links to get c6 run on my beagle board
Why not follow the steps at http://www.angstrom-distribution.org/demo/beagleboard/ ?
