problem reading digital IO pin
I can write to it fine using these commands:
     echo 7 >/sys/kernel/debug/omap_mux/gpmc_ad0
     echo 32 >/sys/class/gpio/export
     echo high >/sys/class/gpio/gpio32/direction
Using low in stead of high switches from 3.3V to 0V and back
as expected.
However, subsequent commands like this:
    echo in >/sys/class/gpio/gpio32/direction
    cat /sys/class/gpio/gpio32/direction/value
Always print 0, regardless of whether its hooked to 3.3V or not.
Interestingly, the output of
    cat /sys/kernel/debug/omap_mux/board/core
changes after 'echo high ...' to indicate that the pin is configured
as an output, but never changes back. But even if I check
/sys/class/gpio/gpio32/value before ever writing to direction,
it doesn't reflect the actual voltage on the pin.
Any help or advice greatly appreciated,
Britton
