I’ve started using the beaglebone recently and bought the replicape rev B3 to hook it to a delta printer.
I am wondering if anyone is also having problems with getting the z-probe to work? I use a inductive 5v end-stop. On the hardware side everything is working, it shows in the terminal when i trigger the z-probe. But doesn’t react when it is probing.
I connected the probe to z2, and modified the config file:
I am also going through my Replicape Delta setup. Slow but getting results. One thing to note is that your bed probe will always be the opposite of the top end-stops. So if your top end-stops are connected and configured for CCW (counter-clock-wise) then your bed probe will be CW (clock-wise). It is the way the motors turn.
For example, my end-stops config below (pin probe with microswitch)
