" MACHINE=beaglebone ./oebb.sh bitbake virtual/kernel" completes with out error
. ./environment-angstromv2012.05
when I try " bitbake cloud9-gnome-image "
At some point my Virtual Box with Ubuntu 12.04 LTS aborts. After a few times starting the VM again I came to this point without crashing.
DEBUG: SITE files [‘endian-little’, ‘bit-32’, ‘arm-common’, ‘common-linux’, ‘common-glibc’, ‘arm-linux’, ‘arm-linux-gnueabi’, ‘common’] ERROR: Function failed: do_compile (see /setup-scripts/build/tmp-angstrom_v2012_05-eglibc/work/armv7a-angstrom-linux-gnueabi/libusb1-1.0.8-r4/temp/log.do_compile.9643 for further information) NOTE: make -j1 make: *** No targets. Stop. ERROR: oe_runmake failed
looking in /setup-scripts/build/tmp-angstrom_v2012_05-eglibc/work/armv7a-angstrom-linux-gnueabi/libusb1-1.0.8-r4/libusb1-1.0.8
I see many files that have 0 size including the Makefile (guessing this is why I am getting the error).
How is the best way to recover the files, if this is the problem?
I can’t run the “MACHINE=beaglebone ./oebb.sh bitbake systemd-image”. An error occurred while processing.
ramon@debian3:~/Damarc/beaglebone/setup-scripts$ MACHINE=beaglebone bitbake systemd-image
Traceback (most recent call last):
File “/usr/local/bitbake/bin/bitbake”, line 34, in
I didn’t apt-get install, I downloaded bitbake and installed it doing make and make install prefix /usr/local/bitbake. After thar I added the path: export PATH… when I type bit+tab, the bitbake will appear on the command line??? I’m confussed.
ERROR: Unable to parse /home/ramon/Damarc/beaglebone/setup-scripts/sources/meta-smartphone/meta-htc/conf/layer.conf: [Errno 2] No such file or directory: ‘/home/ramon/Damarc/beaglebone/setup-scripts/sources/meta-smartphone/meta-htc/conf/layer.conf’
Thanks Koen, I follow the instructions after reinstall debia in my computer and it works perfectly. I build the kernel for the beaglebone, but I have questions:
Where is the compiled file (or files)?
Are these files wich I have to copy in the SD?
Could I edit these files to change the setup of the kernel to my beaglebone?
Thanks in advance!
Ok, I find the information about the compiled files.
I have this files in my pc:
-uImage-3.2-r11l+gitr720e07b4c1f687b61b147b31c698cb6816d72f01-beaglebone-20120522141217.bin
-modules-3.2.16-r11l+gitr720e07b4c1f687b61b147b31c698cb6816d72f01-beaglebone.tgz
-config-3.2-r11l+gitr720e07b4c1f687b61b147b31c698cb6816d72f01-beaglebone.config
and these images can now be copied to the SD-CARD??
I don’t have any *.img.xz, *.img.gz or rootfs.tar.bz2
I’m confused.
THANKS!!
