Hi All,
Hi found out the problem that why am I getting the Kernel Panic when I
build the image with ALSA. My ALSA is able to work in a good manner
but after some time I get the Kernel Panic Error.
The reason is that when I build the kernel I use the gcc from
/opt/arm-2007q3/bin
and
when I make the Android_RFS
I use the internal toolchain which is arm-eabo-4.2.1.
Now there is a mismatch in toolchain. This is causing a problem of
kernel panic and not syncing. Did anyone came across this problem
earlier? or anyone suggest me answer to this and workaround for
solution.
