hi. all
I want to know if gst ti plugin can work properly with phonon, or
has it been tested with phonon?
I want to tell you what I had done with this plugin and phonon. At
first, I got gst ti pluign work well on beagleboard, I can play
video/audio using this plugin. I use DMAI_DEBUG=2 to trace the log,
and I can see some debug messages from DMAI. And I also note that the
cpu is loaded only about 10%. Of course, this had been done using
gst-launch, and create a proper pipeline using commnad. I tested as
following:
gst-launch filesrc location=/media/ram/4.mp4 ! typefind ! qtdemux
name=demux demux.audio_00 ! queue max-size-buffers=1800
max-size-time=0 max-size-bytes=0 ! typefind ! TIAuddec1 ! alsasink
demux.video_00 ! typefind ! TIViddec2 ! TIDmaiVideoSink
videoStd=D1_NTSC displayDevice=/dev/fb2 displayStd=fbdev
resizer=FALSE accelFrameCopy=TRUE
Since previous has worked, so I want to know what about phonon to
use this plugin, in order to get dsp acceleration. I use pnonon to
play a video, the TI watermark is at the top right corner of the
video, and the trace log shows something from DMAI, like this
"@0x006252af:[T:0x4668d490] ti.sdo.dmai - [Vdec2] VIDDEC2_process()
ret 0 inId 2 inUse 0 consumed 40".
To my surprise, when I watch the cpu load, the cpu has been loaded
about 97% and even above that. it seems like I don't get the dsp
accelerator worked. I attached the log what I captured from console,
want to give you more detail about this trace.
is there any problem? what's wrong with phonon and this plugin? any
suggestion is highly appreciated
can gst ti plugin work with pnonon? does phonon source code needed
to be modified according to gst ti plugin interfaces?
thanks
/favor
