So i'm complete noob to the beagle board and simply trying to get
linux running on it. I'm using the image that comes with the board,
and according to the person that i got this board from it worked just
fine previously, but now this is what is simply restarts right after
is says "done, booting the kernel." This just keeps on happening and
Linux never boots.
Any help is greatly appreciated.
Here's the console ouput:
===================================<CONSOLE>======================================
ng the kernel.
Texas Instruments X-Loader 1.5.0 (Mar 27 2011 - 17:37:56)
Beagle xM
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2011.03-rc1-00000-g9a3cc57-dirty (Apr 01 2011 - 17:41:42)
OMAP3630/3730-GP ES2.1, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev C
No EEPROM on expansion board
Die ID #6b4200029ff800000160a74506026016
The user button is currently NOT pressed.
SD/MMC found on device 0
reading uEnv.txt
134 bytes read
Importing environment from mmc ...
Loading file "/boot/uImage" from mmc device 0:2 (xxa2)
3194256 bytes read
Booting from mmc ...
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Angstrom/2.6.32/beagleboard
Data Size: 3194192 Bytes = 3 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux................................................................................................................................................................................................................
