Problems booting preinstalled OMAP3 Natty (11.04) Image on the BeagleBoard rev C4
I'm trying to install Ubuntu Natty on the beagle board rev c4.
These are the steps followed :
0.Got the Ubuntu Natty image from : http://cdimage.ubunt…mel+omap.img.gz
1.Inserted the SD card in my host computer's SD card reader.
2.Identified the correct device name.
3.Ran the following command to write it:
sudo sh -c 'zcat ubuntu-11.04-preinstalled-headless-armel+<omap
.img.gz > /dev/<device name>'
sync
4.Ran Putty on the host computer (running on Ubuntu 10.10 x86) using
these parameters :
a) Set the serial port to /dev/ttyS0.
b) Set the communications settings to 115200 8N1.
c) Turned Hardware Flow Control off.
d) Set the Software Flow Control off.
e) Turned on the Beagle Board and followed the instructions explained
at the bottom of this page :
https://wiki.ubuntu…HeadlessInstall
On omap3 systems with a modified NAND (i.e. beaglebord C series) done
the following:
On a serial console connected to the system, halted the autoboot
script and typed :
setenv bootcmd 'mmc init;fatload mmc 0 0x82000000 boot.scr;source
0x82000000'; setenv autostart yes; saveenv; boot
the picture here : http://www.flickr.com/photos/26687972@N03/5713403636/sizes/l/in/photostream/
explains what happened.
Replace “mmc init” with “mmc rescan 0”
Lioric
or also try “mmcinit” if “mmc rescan 0” doesnt work
