Problems getting started with BeagleBoard-xM
I would like to write a Linux app, copy it to the BeagleBoard-xM, and
debug it from my PC through gdb/gdbserver.
My setup: I have a serial port cable connecting my BeagleBoard-xM to
my PC and I use Hyperterminal to look at the terminal output from the
board. The BeagleBoard-xM is powered by a 5V power supply. I also
have a USB cable connecting the BeaglBoard-xM to my PC since I wanted
to use ethernet over USB.
I installed the Angstrom demo image onto the microSD card by following
the instructions here:
http://www.ibm.com/developerworks/opensource/library/l-beagleboard-xm/index.html
When I try booting Linux with the USB cable not connected, everything
is fine. I can log into the Linux command line. If I connect the USB
cable, I get a "Kernel panic - not syncing: Fatal exception in
interrupt" error.
When I try booting Linux with the USB cable connected, I get the same
"Kernel panic" error.
How do I fix this problem and get ethernet working?
norman,
Try booting with irqpoll kernel parameter. And also, post the kernel
boot log if you can, it would help alot.
-toan
In U-Boot, I typed the following commands to set the irqpoll
parameter:
setenv bootargs irqpoll
boot
I still get the kernel panic error. Am I setting the irqpoll
parameter correctly?
Here are the last 500 lines of the boot log:
[ 57.484344] r10: 00000000 r9 : 00000099 r8 : 00000009
[ 57.489593] r7 : 00000000 r6 : df81f108 r5 : 00000001 r4 :
00000000
[ 57.496154] r3 : 00000000 r2 : 00000000 r1 : fa0ab000 r0 :
df81f108
[ 57.502716] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM
Segment ker
nel
[ 57.510131] Control: 10c5387d Table: 80004019 DAC: 00000017
[ 57.515899] Process swapper (pid: 0, stack limit = 0xc06262f0)
[ 57.521759] Stack: (0xc0627ee0 to 0xc0628000)
[ 57.526153] 7ee0: 3173eef6 33390598 31bf5ede 00000000 315c2f4a
df81f108 60000
113 df892900
[ 57.534362] 7f00: c0626000 0000005c 00000000 00000000 c066dac0
c03419a0 c0627
f48 df892900
[ 57.542572] 7f20: c063b148 c00a4328 00000000 df892900 c063b148
0000005c 00000
002 00000001
[ 57.550811] 7f40: c0626000 0000001f 00000000 c00a64f0 0000005c
00000000 c0629
e84 c003b074
[ 57.559020] 7f60: 00000001 ffffffff fa200000 c003bb44 00000000
80000013 80000
013 00000000
[ 57.567230] 7f80: c0626000 c0629fe0 c0629e84 c0671acc 8002f154
413fc082 00000
01f 00000000
[ 57.575469] 7fa0: c0639138 c0627fbc c004ba8c c004c2e4 60000013
ffffffff 00000
000 c003cfc4
[ 57.583679] 7fc0: 00000000 c06b8ba0 c0671a90 c0031010 c0629e78
c0008984 c0008
498 00000000
[ 57.591888] 7fe0: 00000000 c0031010 10c53c7d c0671b20 c0031414
80008034 00000
000 00000000
[ 57.600128] [<c034177c>] (musb_interrupt+0x9f8/0xbb8) from
[<c03419a0>] (gene
ric_interrupt+0x64/0xa8)
[ 57.609405] [<c03419a0>] (generic_interrupt+0x64/0xa8) from
[<c00a4328>] (han
dle_IRQ_event+0xac/0x1ec)
[ 57.618743] [<c00a4328>] (handle_IRQ_event+0xac/0x1ec) from
[<c00a64f0>] (han
dle_level_irq+0xbc/0x148)
[ 57.628112] [<c00a64f0>] (handle_level_irq+0xbc/0x148) from
[<c003b074>] (asm
_do_IRQ+0x74/0x98)
[ 57.636871] [<c003b074>] (asm_do_IRQ+0x74/0x98) from [<c003bb44>]
(__irq_svc+
0x44/0xa8)
[ 57.644897] Exception stack(0xc0627f70 to 0xc0627fb8)
[ 57.649963] 7f60: 00000000
80000013 80000
013 00000000
[ 57.658203] 7f80: c0626000 c0629fe0 c0629e84 c0671acc 8002f154
413fc082 00000
01f 00000000
[ 57.666412] 7fa0: c0639138 c0627fbc c004ba8c c004c2e4 60000013
ffffffff
[ 57.673065] [<c003bb44>] (__irq_svc+0x44/0xa8) from [<c004c2e4>]
(omap3_pm_id
le+0x4c/0x50)
[ 57.681365] [<c004c2e4>] (omap3_pm_idle+0x4c/0x50) from
[<00000000>] (0x0)
[ 57.688293] Code: e3530003 13a02000 05963078 05933018 (05d33014)
[ 57.694488] ---[ end trace a41efe6e49b6a7f6 ]---
[ 57.699127] Kernel panic - not syncing: Fatal exception in
interrupt
Texas Instruments X-Loader 1.4.4ss (Jan 4 2011 - 12:38:07)
Beagle xM Rev A
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2010.03 (Jan 04 2011 - 12:38:02)
OMAP3630/3730-GP ES2.0, CPU-OPP2, L3-165MHz,
I2C: ready
DRAM: 512 MB
NAND: 0 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Probing for expansion boards, if none are connected you'll see a
harmless I2C er
ror.
No EEPROM on expansion board
Beagle xM Rev A
Die ID #387e00011ff00000015739eb08006017
mmc1 is available
The user button is currently NOT pressed.
reading boot.scr
** Unable to read "boot.scr" from mmc 1:1 **
reading uImage
3195484 bytes read
Booting from mmc ...
## Booting kernel from Legacy Image at 80200000 ...
   Image Name: Angstrom/2.6.32/beagleboard
   Data Size: 3195420 Bytes = 3 MB
   Load Address: 80008000
   Entry Point: 80008000
   Verifying Checksum ...
Beagle xM Rev A
Reading boot sector
I2C: ready
DRAM: 512 MB
NAND: 0 MiB
In: serial
Out: serial
Err: serial
harmless I2C er
ror.
Beagle xM Rev A
OMAP3 beagleboard.org # setenv bootargs irqpoll
OMAP3 beagleboard.org # boot
mmc1 is available
reading boot.scr
reading uImage
3195484 bytes read
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux.............................................................
done, booti
ng the kernel.
[ 0.000000] Linux version 2.6.32 (koen@dominion) (gcc version 4.3.3
(GCC) ) #
3 PREEMPT Thu Jan 6 17:37:46 CET 2011
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7),
cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing
instruction ca
che
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630/DM3730 ES1.0 (l2cache iva sgx neon isp
192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x100000
[ 0.000000] Reserving 12582912 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pag
es: 130048
[ 0.000000] Kernel command line: console=ttyS2,115200n8
mpurate=1000 buddy=no
ne camera=lbcm3m1 vram=12M omapfb.mode=dvi:640x480MR-16@60
omapdss.def_disp=dvi
root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
[ 0.000000] Beagle expansionboard: none
[ 0.000000] Beagle cameraboard: lbcm3m1
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6,
262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072
bytes)
[ 0.000000] Memory: 256MB 256MB = 512MB total
[ 0.000000] Memory: 500352KB available (5900K code, 671K data, 204K
init, 0K
highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz
[ 0.000000] Reprogramming SDRC clock to 332000000 Hz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrupt
s
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop... 507.32 BogoMIPS (lpj=1982464)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] tmpfs: No value for mount option 'mode'
[ 0.000000] devtmpfs: initialized
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] Beagle cameraboard: registering i2c2 bus for lbcm3m1
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 0.000000] Unable to get DVI reset GPIO
[ 0.000000] omap_init_mbox: platform not supported
[ 0.000000] Target VDD1 OPP = 4, VDD2 OPP = 2
[ 33.708190] OMAP DMA hardware revision 5.0
[ 33.714385] bio: create slab <bio-0> at 0
[ 33.715667] SCSI subsystem initialized
[ 33.716979] usbcore: registered new interface driver usbfs
[ 33.717102] usbcore: registered new interface driver hub
[ 33.717254] usbcore: registered new device driver usb
[ 33.717651] i2c_omap i2c_omap.1: bus 1 rev4.0 at 2600 kHz
[ 33.720336] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 33.720367] twl4030: power (irq 373) chaining IRQs 376..383
[ 33.720642] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 33.722351] regulator: VUSB1V5: 1500 mV normal standby
[ 33.722564] regulator: VUSB1V8: 1800 mV normal standby
[ 33.722778] regulator: VUSB3V1: 3100 mV normal standby
[ 33.726409] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 33.726776] regulator: VMMC1: 1850 <--> 3150 mV normal standby
[ 33.727050] regulator: VDAC: 1800 mV normal standby
[ 33.727264] regulator: VPLL2: 1800 mV normal standby
[ 33.727508] regulator: VSIM: 1800 <--> 3000 mV normal standby
[ 33.727844] regulator: VAUX3: 1800 mV normal standby
[ 33.728179] regulator: VAUX4: 1800 mV normal standby
[ 33.728332] i2c_omap i2c_omap.2: bus 2 rev4.0 at 400 kHz
[ 33.737426] i2c_omap i2c_omap.3: bus 3 rev4.0 at 100 kHz
[ 33.738586] Switching to clocksource 32k_counter
[ 33.747558] musb_hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 33.747833] musb_hdrc: USB OTG mode controller at fa0ab000 using
DMA, IRQ 92
[ 33.747863] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 33.747985] musb_hdrc musb_hdrc: new USB bus registered, assigned
bus number
1
[ 33.748107] usb usb1: New USB device found, idVendor=1d6b,
idProduct=0002
[ 33.748138] usb usb1: New USB device strings: Mfr=3, Product=2,
SerialNumber=
1
[ 33.748138] usb usb1: Product: MUSB HDRC host driver
[ 33.748168] usb usb1: Manufacturer: Linux 2.6.32 musb-hcd
[ 33.748168] usb usb1: SerialNumber: musb_hdrc
[ 33.748809] hub 1-0:1.0: USB hub found
[ 33.748840] hub 1-0:1.0: 1 port detected
[ 33.749908] NET: Registered protocol family 2
[ 33.750122] IP route cache hash table entries: 4096 (order: 2,
16384 bytes)
[ 33.750640] TCP established hash table entries: 16384 (order: 5,
131072 bytes
[ 33.751037] TCP bind hash table entries: 16384 (order: 4, 65536
bytes)
[ 33.751251] TCP: Hash tables configured (established 16384 bind
16384)
[ 33.751251] TCP reno registered
[ 33.751281] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 33.751312] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 33.751525] NET: Registered protocol family 1
[ 33.751953] RPC: Registered udp transport module.
[ 33.751983] RPC: Registered tcp transport module.
[ 33.751983] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 33.752868] omap-iommu omap-iommu.0: isp registered
[ 33.754699] VFS: Disk quotas dquot_6.5.2
[ 33.754791] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 33.755859] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 33.756652] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red
Hat, Inc.
[ 33.757446] msgmni has been set to 977
[ 33.761108] alg: No test for stdrng (krng)
[ 33.761383] Block layer SCSI generic (bsg) driver version 0.4
loaded (major 2
54)
[ 33.761413] io scheduler noop registered
[ 33.761444] io scheduler deadline registered
[ 33.761566] io scheduler cfq registered (default)
[ 33.824798] OMAP DSS rev 2.0
[ 33.824859] OMAP DISPC rev 3.0
[ 33.824920] OMAP VENC rev 2
[ 33.825164] OMAP DSI rev 1.0
[ 34.161773] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 34.179901] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
[ 34.197387] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
[ 34.214843] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
[ 34.781982] console [ttyS2] enabled
[ 34.792053] brd: module loaded
[ 34.798339] loop: module loaded
[ 34.802764] omap2-nand driver initializing
[ 34.807128] No NAND device found!!!
[ 34.810852] No NAND device found!!!
[ 34.815338] usbcore: registered new interface driver catc
[ 34.820831] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 34.826904] usbcore: registered new interface driver kaweth
[ 34.832550] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB
Ethernet dr
iver
[ 34.840148] usbcore: registered new interface driver pegasus
[ 34.845855] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet
driver
[ 34.852874] usbcore: registered new interface driver rtl8150
[ 34.858673] usbcore: registered new interface driver asix
[ 34.864227] usbcore: registered new interface driver cdc_ether
[ 34.870147] usbcore: registered new interface driver dm9601
[ 34.875854] usbcore: registered new interface driver smsc95xx
[ 34.881744] usbcore: registered new interface driver gl620a
[ 34.887451] usbcore: registered new interface driver net1080
[ 34.893218] usbcore: registered new interface driver plusb
[ 34.898834] usbcore: registered new interface driver rndis_host
[ 34.904876] usbcore: registered new interface driver cdc_subset
[ 34.910919] usbcore: registered new interface driver zaurus
[ 34.916595] usbcore: registered new interface driver MOSCHIP usb-
ethernet dri
ver
[ 34.924652] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 34.931488] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 34.937530] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus numbe
r 2
[ 34.945129] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 34.965301] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 34.971191] usb usb2: New USB device found, idVendor=1d6b,
idProduct=0002
[ 34.978057] usb usb2: New USB device strings: Mfr=3, Product=2,
SerialNumber=
1
[ 34.985351] usb usb2: Product: OMAP-EHCI Host Controller
[ 34.990692] usb usb2: Manufacturer: Linux 2.6.32 ehci_hcd
[ 34.996154] usb usb2: SerialNumber: ehci-omap.0
[ 35.001373] hub 2-0:1.0: USB hub found
[ 35.005218] hub 2-0:1.0: 3 ports detected
[ 35.035705] Initializing USB Mass Storage driver...
[ 35.040802] usbcore: registered new interface driver usb-storage
[ 35.046875] USB Mass Storage support registered.
[ 35.051910] mice: PS/2 mouse device common for all mice
[ 35.057556] input: gpio-keys as /devices/platform/gpio-keys/input/
input0
[ 35.065368] input: twl4030_pwrbutton as /devices/platform/i2c_omap.
1/i2c-1/1-
0049/twl4030_pwrbutton/input/input1
[ 35.076110] i2c /dev entries driver
[ 35.080200] Linux video capture interface: v2.00
[ 35.085144] omap-iommu omap-iommu.0: isp: version 1.1
[ 35.091522] vpfe_init
[ 35.094390] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 35.207855] mmci-omap-hs mmci-omap-hs.1: err -16 configuring card
detect
[ 35.214874] Registered led device: beagleboard::usr0
[ 35.220031] Registered led device: beagleboard::usr1
[ 35.226654] Registered led device: beagleboard::pmu_stat
[ 35.233734] usbcore: registered new interface driver usbhid
[ 35.239379] usbhid: USB HID core driver
[ 35.243408] Advanced Linux Sound Architecture Driver Version
1.0.21.
[ 35.250305] usbcore: registered new interface driver snd-usb-audio
[ 35.313659] No device for DAI omap-mcbsp-dai-0
[ 35.318145] No device for DAI omap-mcbsp-dai-1
[ 35.322631] No device for DAI omap-mcbsp-dai-2
[ 35.327117] No device for DAI omap-mcbsp-dai-3
[ 35.331573] No device for DAI omap-mcbsp-dai-4
[ 35.336090] OMAP3 Beagle SoC init
[ 35.340270] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 35.351776] ALSA device list:
[ 35.354797] #0: omap3beagle (twl4030)
[ 35.358764] oprofile: using arm/armv7
[ 35.362670] TCP cubic registered
[ 35.365966] NET: Registered protocol family 17
[ 35.370483] NET: Registered protocol family 15
[ 35.375061] lib80211: common routines for IEEE802.11 drivers
[ 35.380798] ThumbEE CPU extension supported.
[ 35.385101] Power Management for TI OMAP3.
[ 35.389617] usb 2-2: new high speed USB device using ehci-omap and
address 2
[ 35.397674] Unable to set L3 frequency (400000000)
[ 35.402587] Switched to new clocking rate (Crystal/Core/MPU):
26.0/332/1000 M
Hz
[ 35.409973] IVA2 clocking rate: 800 MHz
[ 35.590270] SmartReflex driver initialized
[ 35.594512] omap3beaglelmb: Driver registration complete
[ 35.605316] VFP support v0.3: implementor 41 architecture 3 part 30
variant c
rev 3
[ 35.613586] registered taskstats version 1
[ 35.618438] fbcvt: 640x480@60: CVT Name - .307M3-R
[ 35.632171] Console: switching to colour frame buffer device 80x30
[ 35.644287] regulator_init_complete: incomplete constraints,
leaving VAUX3 on
[ 35.654937] regulator_init_complete: incomplete constraints,
leaving VDAC on
[ 35.662200] omap_vout omap_vout: probed for an unknown device
[ 35.668304] Waiting for root device /dev/mmcblk0p2...
[ 35.715759] usb 2-2: New USB device found, idVendor=0424,
idProduct=9514
[ 35.722503] usb 2-2: New USB device strings: Mfr=0, Product=0,
SerialNumber=0
[ 35.730377] hub 2-2:1.0: USB hub found
[ 35.734344] hub 2-2:1.0: 5 ports detected
[ 35.777709] mmc0: new high speed SDHC card at address 1234
[ 35.783599] mmcblk0: mmc0:1234 SA04G 3.67 GiB
[ 35.788330] mmcblk0: p1 p2
[ 36.028015] usb 2-2.1: new high speed USB device using ehci-omap
and address
3
[ 36.153137] usb 2-2.1: New USB device found, idVendor=0424,
idProduct=ec00
[ 36.160583] usb 2-2.1: New USB device strings: Mfr=0, Product=0,
SerialNumber
=0
[ 36.171508] smsc95xx v1.0.4
[ 36.226654] usb0: register 'smsc95xx' at usb-ehci-omap.0-2.1,
smsc95xx USB 2.
0 Ethernet, 6a:ff:6b:ad:b9:99
[ 36.358367] Unable to handle kernel NULL pointer dereference at
virtual addre
ss 00000014
[ 36.366516] pgd = c0004000
[ 36.369232] [00000014] *pgd=00000000
[ 36.372833] Internal error: Oops: 5 [#1] PREEMPT
[ 36.377471] last sysfs file:
[ 36.380462] Modules linked in:
[ 36.383514] CPU: 0 Not tainted (2.6.32 #3)
[ 36.388000] PC is at musb_interrupt+0x9f8/0xbb8
[ 36.392547] LR is at musb_interrupt+0x9e4/0xbb8
[ 36.397094] pc : [<c034177c>] lr : [<c0341768>] psr: 60000193
[ 36.397125] sp : df825b88 ip : df825bc0 fp : 000000f0
[ 36.408630] r10: 00000000 r9 : 00000099 r8 : 00000009
[ 36.413879] r7 : 00000000 r6 : df81f108 r5 : 00000001 r4 :
00000000
[ 36.420440] r3 : 00000000 r2 : 00000000 r1 : fa0ab000 r0 :
df81f108
[ 36.427001] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM
Segment ker
nel
[ 36.434417] Control: 10c5387d Table: 80004019 DAC: 00000017
[ 36.440216] Process swapper (pid: 1, stack limit = 0xdf8242f0)
[ 36.446075] Stack: (0xdf825b88 to 0xdf826000)
[ 36.450439] 5b80: 00000003 c06369c8 00000000
df825ba0 c00c4
d6c df81f108
[ 36.458648] 5ba0: 60000113 df892900 df824000 0000005c 00000000
00000000 c066d
ac0 c03419a0
[ 36.466888] 5bc0: c066d864 df892900 c063b148 c00a4328 00000000
df892900 c063b
148 0000005c
[ 36.475097] 5be0: 00000002 00000001 df824000 c010fee4 00000000
c00a64f0 00000
05c 00000000
[ 36.483306] 5c00: df5041c8 c003b074 00000000 ffffffff fa200000
c003bb44 00000
000 00000050
[ 36.491516] 5c20: df807200 00000003 60000013 df808f40 df5041c8
00000050 00000
050 c0ab5ba0
[ 36.499755] 5c40: c010fee4 00000000 00000004 df825c60 c00e99bc
c00e9a10 60000
013 ffffffff
[ 36.507965] 5c60: 00000000 df825c70 c00c8090 c0ab5ba0 00000000
00000000 00001
000 00000000
[ 36.516174] 5c80: 00000000 c010fee4 c0ab5ba0 c01107cc c0ab5ba0
00000000 00068
62c 00000000
[ 36.524414] 5ca0: df402a40 00001000 0006862c c0110eb8 00001000
df402b68 00000
429 df824000
[ 36.532623] 5cc0: df825d40 00000429 00000422 c010052c c0643c7c
c0198238 df4f8
c48 df4e8408
[ 36.540832] 5ce0: df4e8988 00000007 dfb2e400 df504388 00000429
00000422 00000
442 00000000
[ 36.549072] 5d00: df825d20 c0194d40 00001000 df402a40 000001aa
df825d00 00001
000 df825d80
[ 36.557281] 5d20: df504388 df504348 df504308 df5042c8 df504288
df504248 df504
208 c0ab5aa0
[ 36.565490] 5d40: 0006862c 00068625 000004cc df4f8c48 dfe3204c
00000423 00000
422 dfb2e400
[ 36.573699] 5d60: df825db4 00000002 000004cc c0195008 00001000
c04892bc 00000
002 00000000
[ 36.581939] 5d80: 00000000 df4e8588 df823b40 00000000 dfb2e400
df825db4 00000
001 00000002
[ 36.590148] 5da0: dfb1ddc0 00000000 dfb2e600 c01953b0 00000000
00000432 00000
4f3 00000366
[ 36.598358] 5dc0: 00000004 00000004 dfb2e400 00000000 dfb1ddc0
c0197d0c 00000
000 dfb2e400
[ 36.606597] 5de0: 00000008 c01558c8 00001000 00000000 00000010
00000002 ff7fc
000 000001fe
[ 36.614807] 5e00: 00100000 00000000 1fffffff 00000000 00000001
0000000c df4dc
4c8 c06d1400
[ 36.623016] 5e20: 00000000 00000001 00000001 00000000 c064455c
dfb2ee0c dfb2e
e00 df825e88
[ 36.631225] 5e40: 00000002 00008000 dfb211c0 00000000 00000000
00000000 00000
000 00000000
[ 36.639465] 5e60: dfb2e774 dfb2e600 df402aa8 df402a40 00000003
00008000 dfb21
1c0 00000000
[ 36.647674] 5e80: 00000000 c00ef210 62636d6d 70306b6c dfb20032
df80b1a0 dfb2f
440 dfb2f400
[ 36.655883] 5ea0: 0000000a c00d2e4c df80b140 df80b140 dfb2f440
c064455c 00008
000 00000000
[ 36.664123] 5ec0: 00000000 c015252c c0154984 df80b140 00000000
c00edcf8 df80b
140 c01039b8
[ 36.672332] 5ee0: 00008000 dfb2f440 00000000 dfb211c0 c064455c
c00eddc0 00008
000 00000000
[ 36.680541] 5f00: 00000000 00000020 dfb2f440 c0106d58 df824000
dfb2f440 00000
00a 00000000
[ 36.688781] 5f20: df80b7c0 df458818 00000000 dfb4d000 c056c27f
00008000 00008
000 c056c27f
[ 36.696990] 5f40: 00000000 c0106e60 00000000 df80b7c0 df458a18
00000000 dfb2f
440 dfb211c0
[ 36.705200] 5f60: df808e40 df907000 df907005 c0030a50 df907000
c0008be0 00000
000 00000000
[ 36.713409] 5f80: 00000000 df907000 df907005 c0008e54 c0683fc0
62636d6d 00000
080 c0638e90
[ 36.721649] 5fa0: c0638ea0 df907000 00000000 0000b302 c0671a78
c0030a08 00000
000 00000000
[ 36.729858] 5fc0: 00000000 00000000 00000000 c00091dc c0671858
c002fb80 00000
000 c0671858
[ 36.738067] 5fe0: c002fb80 c0008458 00000000 00000000 00000000
c003c9fc 4064c
000 02008810
[ 36.746307] [<c034177c>] (musb_interrupt+0x9f8/0xbb8) from
[<c03419a0>] (gene
[ 36.755584] [<c03419a0>] (generic_interrupt+0x64/0xa8) from
[<c00a4328>] (han
[ 36.764953] [<c00a4328>] (handle_IRQ_event+0xac/0x1ec) from
[<c00a64f0>] (han
[ 36.774291] [<c00a64f0>] (handle_level_irq+0xbc/0x148) from
[<c003b074>] (asm
_do_IRQ+0x74/0x98)
[ 36.783050] [<c003b074>] (asm_do_IRQ+0x74/0x98) from [<c003bb44>]
(__irq_svc+
0x44/0xa8)
[ 36.791076] Exception stack(0xdf825c18 to 0xdf825c60)
[ 36.796173]
5c00: 00000
000 00000050
[ 36.804382] 5c20: df807200 00000003 60000013 df808f40 df5041c8
00000050 00000
050 c0ab5ba0
[ 36.812591] 5c40: c010fee4 00000000 00000004 df825c60 c00e99bc
c00e9a10 60000
013 ffffffff
[ 36.820831] [<c003bb44>] (__irq_svc+0x44/0xa8) from [<c00e9a10>]
(kmem_cache_
alloc+0x80/0x140)
[ 36.829467] [<c00e9a10>] (kmem_cache_alloc+0x80/0x140) from
[<c010fee4>] (all
oc_buffer_head+0x14/0xa8)
[ 36.838836] [<c010fee4>] (alloc_buffer_head+0x14/0xa8) from
[<c01107cc>] (all
oc_page_buffers+0x28/0xbc)
[ 36.848266] [<c01107cc>] (alloc_page_buffers+0x28/0xbc) from
[<c0110eb8>] (__
getblk+0x250/0x3b4)
[ 36.857116] [<c0110eb8>] (__getblk+0x250/0x3b4) from [<c0194d40>]
(jread+0x11
0/0x250)
[ 36.864990] [<c0194d40>] (jread+0x110/0x250) from [<c0195008>]
(do_one_pass+0
x188/0x444)
[ 36.873107] [<c0195008>] (do_one_pass+0x188/0x444) from
[<c01953b0>] (journal
_recover+0x84/0xbc)
[ 36.881958] [<c01953b0>] (journal_recover+0x84/0xbc) from
[<c0197d0c>] (journ
al_load+0x58/0xa0)
[ 36.890686] [<c0197d0c>] (journal_load+0x58/0xa0) from [<c01558c8>]
(ext3_fil
l_super+0xf44/0x1750)
[ 36.899719] [<c01558c8>] (ext3_fill_super+0xf44/0x1750) from
[<c00ef210>] (ge
t_sb_bdev+0x114/0x16c)
[ 36.908813] [<c00ef210>] (get_sb_bdev+0x114/0x16c) from
[<c015252c>] (ext3_ge
t_sb+0x1c/0x28)
[ 36.917297] [<c015252c>] (ext3_get_sb+0x1c/0x28) from [<c00edcf8>]
(vfs_kern_
mount+0x50/0xd4)
[ 36.925842] [<c00edcf8>] (vfs_kern_mount+0x50/0xd4) from
[<c00eddc0>] (do_ker
n_mount+0x34/0xd8)
[ 36.934600] [<c00eddc0>] (do_kern_mount+0x34/0xd8) from
[<c0106d58>] (do_moun
t+0x700/0x784)
[ 36.942993] [<c0106d58>] (do_mount+0x700/0x784) from [<c0106e60>]
(sys_mount+
0x84/0xc4)
[ 36.951049] [<c0106e60>] (sys_mount+0x84/0xc4) from [<c0008be0>]
(do_mount_ro
ot+0x20/0xb4)
[ 36.959350] [<c0008be0>] (do_mount_root+0x20/0xb4) from
[<c0008e54>] (mount_b
lock_root+0xf8/0x21c)
[ 36.968353] [<c0008e54>] (mount_block_root+0xf8/0x21c) from
[<c00091dc>] (pre
pare_namespace+0x164/0x1d4)
[ 36.977874] [<c00091dc>] (prepare_namespace+0x164/0x1d4) from
[<c0008458>] (k
ernel_init+0xe8/0x128)
[ 36.986968] [<c0008458>] (kernel_init+0xe8/0x128) from [<c003c9fc>]
(kernel_t
hread_exit+0x0/0x8)
[ 36.995788] Code: e3530003 13a02000 05963078 05933018 (05d33014)
[ 37.001983] ---[ end trace 0ef3f32e40ecc1e7 ]---
[ 37.006652] Kernel panic - not syncing: Fatal exception in interrupt
It is a known issue with the demo image provided in the SD
  • Use another distro
  • Use a newer kernel
  • Compile your newer kernel
  • don’t let kernel to auto load the g_ether module, and set a script to modprobe it after boot is complete
  • Or just disconnect the usb cable until the board is booted
Lioric
try out with kernel 2.6.32-rc5 and get online angstrom built for beagleboard. boot it from SD card… u will get the board running with flying colors…
