I’ve made a real honest effort to get ubuntu running on the beaglebone, and i’m now suffering from a flat head from all the banging on the table. I’m sure that i’ve probably mis-interpreted what seem like very clear instructions in some way… I’ve tryed downloading several differnet images and get the same results, and i see that other people have been able to use these images, so i’m sure i’ve done somethign wrong.
I have been able to copy the angstrom disto back onto the beagle, and update it, using the same sd-card, and hardware… I’ve also tryed the process on a 2nd beagle bone and differnet card, and get the same result… I’ve tryed powering the beaglebone from both the USB port and the 5V port and it does’nt seem to make much difference.
Here is what i have done;
(1) From my Ubuntu Desktop
(a) got the image via wget ( http://rcn-ee.net/deb/rootfs/quantal/ubuntu-12.10-r2-minimal-armhf-2012-11.29.tar.xz )
(b) unpacked it
© used the script to copy the packages to the sd-card
sudo ./setup_sdcard.sh --mmc /dev/sdd --uboot bone ( my sdcard finds its way to /dev/sdd )
I end up with a card that has two partitions on it, that looks like its ok.
(2) Pop the card into the beaglebone, and start up… connect to its serial port and monitor… it starts to boot up, i can see a whole bunch of messages fly past… it eventually gets to this point and stops.
[ 2.468780] mmc0: new high speed SDHC card at address 1234
[ 2.486785] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[ 2.502044] mmcblk0: p1 p2
[ 2.569732] udevd[67]: starting version 175
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Mounting root file system … Begin: Running /scripts/local-top … done.
[ 3.060821] gadget: high-speed config #1: CDC Ethernet (ECM)
Begin: Running /scripts/local-premount … hwclock: select() to /dev/rtc0 to wait for clock tick timed out: No such file or directory
done.
[ 8.914215] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Begin: Running /scripts/local-bottom … done.
done.
Begin: Running /scripts/init-bottom … done.
There is no output at the console, for about 2 minutes, and then i start getting messages displaying periodically that look like
for_common+0x120/0x158)
[ 240.742889] r5:cf837ac4 r4:7fffffff
[ 240.746643] [] (wait_for_common+0x0/0x158) from [] (wait_for_completion+0x18/0x1c)
[ 240.756408] r8:00000400 r7:00000000 r6:cec84140 r5:00000001 r4:cedd1400
[ 240.763458] [] (wait_for_completion+0x0/0x1c) from [] (flush_work+0x30/0x3c)
[ 240.772705] [] (flush_work+0x0/0x3c) from [] (tty_flush_to_ldisc+0x14/0x18)
[ 240.781799] [] (tty_flush_to_ldisc+0x0/0x18) from [] (n_tty_poll+0x7c/0x178)
[ 240.791015] [] (n_tty_poll+0x0/0x178) from [] (tty_poll+0x68/0x8c)
[ 240.799285] r7:00000000 r6:ced91c00 r5:cedd1400 r4:cec84140
[ 240.805267] [] (tty_poll+0x0/0x8c) from [] (do_select+0x2b8/0x488)
[ 240.813568] r7:00000000 r6:00000002 r5:cf837e20 r4:00000010
[ 240.819519] [] (do_select+0x0/0x488) from [] (core_sys_select+0x22c/0x33c)
[ 240.828552] [] (core_sys_select+0x0/0x33c) from [] (sys_select+0xdc/0x10c)
[ 240.837585] [] (sys_select+0x0/0x10c) from [] (ret_fast_syscall+0x0/0x30)
It will display these messsages for ever and never gets to a login prompt… I am not running it with the ethernet port connected.
FYI. the beaglebone i a Rev.A5A, SN 1912BB000086
I am hoping there is a kind person out there who might be able to point me in the right direction.
I have tryed several different images, and i’ve also tryed some debian images, and they all give me the same result…
Kind regards
