Problems trying to get 1024x768 with DSS2
I've been pulling my hair out for the past week and half trying to get
DDS2 to work at 1024x768.
I'm wanting to run mplayer -fs on the framebuffer at 1024x768 at 24-
bit. If I use the 2.6.27 kernel from:
http://www.angstrom-distribution.org/demo/beagleboard/
mplayer -fs runs with no problem, though it's 16-bit.
I've tried various 2.6.28 and "2.6.27+2.6.28" kernels from koen and
others with DSS2, including a 2.6.8-r25 I build yesterday via open
embedded with bitbake -b packages/linux/linux-omap_2.6.28 (which
definitely has the patch to video modes selectable) and I can switch
the video mode to a 1024x768 resolution, but always mplayer -fs plays
the video squashed into the top left 640x480 region.
No matter what I do /sys/devices/platform/omapfb/framebuffers has:
0 p:8064f000 v:c9000000 size:1228800 t:gfx
1 p:00000000 v:00000000 size:0 t:vid1
2 p:00000000 v:00000000 size:0 t:vid2
1228800 is 6480x480x4, right? And displays has:
dvi e:1 u:1 t:0 h:640/48/80/32 v:480/3/7/4 p:23500
tv e:0 u:-1 t:0 h:720/0/0/0 v:574/0/0/0 p:0
On bootup fbset reports:
mode "640x480-59"
        # D: 23.500 MHz, H: 29.375 kHz, V: 59.464 Hz
        geometry 640 480 640 480 32
        timings 42553 48 80 3 7 32 4
        accel false
        rgba 8/16,8/8,8/0,0/0
endmode
After running various commands like:
echo "dvi h:1024/20/8/30 v:768/4/2/20 p:48000"
fbset -fb /dev/fb0 -xres 1024 -yres 768
fbset will report:
mode "1024x768-25"
        # D: 23.500 MHz, H: 19.848 kHz, V: 25.381 Hz
        geometry 1024 768 640 480 32
        accel false
endmode
and displays has:
dvi e:1 u:1 t:0 h:1024/20/8/30 v:768/4/2/20 p:48000
... but framebuffers always reports:
... and mplayer only dsplays in the top,right corner of the
framebuffer.
(I'm using the 25Hz mode because if I try and use a standard
1024x768@60 timing DSS2 crashes with a null pointer deference as
reported elsewhere - not sure if this is fixed in current kernels or
not)
I believe I've tried adding ,vxvres=1024,vyres=768 parameters which I
think someone suggested by to no avail.
Does anyone have any ideas?
Christopher.
Put 'omapfb.mode=1024x768MR-24@60' in your kernel cmdline.
regards,
Koen
I just tried this and got:
Linux version 2.6.28-omap1 (koen@dominion) (gcc version 4.2.1) #1 Fri
Jan 9 17:10:15 CET
2009
Kernel command line: console=ttyS2,115200n8 console=tty0 root=/dev/
mmcblk0p2 rootwait rootfstype=ext3
Unknown boot option `omapfb.mode=1024x768MR-24@60': ignoring
I don't have a SD card reader here to check but I think this is the
uImage-2.6.28-r5 kernel I built from OE.
I also tried
uImage-2.6.27+2.6.28rc6+r1+gitr3b7de4be
879f1f4f55ae59882a5cbd80f6dcf0f0-r1-beagleboard.bin and got the same
thing.
Cheers,
Christopher.
Op 16 jan 2009 om 16:29 heeft chrisf@goop.org het volgende geschreven:\
Op 14 jan 2009, om 13:52 heeft chr...@goop.org het volgende
geschreven:
get
Omapfb.videomode
I tried the same, but without result
root@beagleboard:~# cat /proc/cmdline
console=ttyS2,115200n8 console=tty0 root=/dev/mmcblk0p2 rootwait
rootfstype=ext3 omapfb.videomode=1024x768MR-24@60
and booting
Unknown boot option `omapfb.videomode=1024x768MR-24@60': ignoring
With 2.6.28 I really can't give parameters to omapfb_main
I read arm/OMAP/DSS documentation and also fb/mode..
but the commandline doesn't work.
I also tried to re-compile the kernel in oe/tmp/work/beagleboard-
angstrom-linux-gnueabi/linux-omap-2.6.28-r0/git but it is the same.
I tried to add some tracing in dirvers/video/omap/omafb_main.c adding
#define DEBUG 1
before the include, but pr_debug doesn't appear ( or maybe the
parameter didn't arrive to omapfb)
and booting
Read it again, this time correctly =).
omapfb.video_mode
        - Default video mode for default display. For example,
          "800x400MR-24@60". See drivers/video/modedb.c
#define DEBUG 1
That doesn't help, as that file is for the old display subsystem.
Tomi
