Problems with am335x-pm-firmware.bin (Beaglebone/Robert Nelsons Kernel)
Happy New Year everybody! :slight_smile:
With a freshly updated kernel of Robert Nelsons kernel tree
I try to include/activate/use the am335x-pm-firmware.bin blob.
I followed this guide:
http://processors.wiki.ti.com/index.php/AM335x_Power_Management_User_guide
The only difference is, that I use the ondemand governor instead of
the userspace one.
I copied the firmware to ....../linux-dev/KERNEL/firmware/am335x-pm-firmware.bin
and build the kernel after checking the settings described in the
guide.
I also copie dthe firmware blob to /lib/firmware on the beaglebone.
But dmesg does not show the magic lines
    [ 2.127075] Trying to load am335x-pm-firmware.bin (60 secs timeout)
    [ 2.137084] Copied the M3 firmware to UMEM
nor can I find the directories
    /sys/devices/system/cpu/cpu0/cpuidle/state0
    /sys/devices/system/cpu/cpu0/cpuidle/state1
on the beaglebone. Beside that, it boots fine.
I am using the defconfig (removed ..../KERNEL/. and build_kernel.sh)
The repository/branch:
    solfire:RobertCNelson/linux-dev>git branch
    * am33x-v3.2
    master
I attached the related config and the output of dmesg gzipped to this email.
What did I wrong? How can I fix it?
Thank you very much in advance for any help!
Best regards,
mcc
dmesg.gz (6.06 KB)
3.2.33-psp26.config.gz (23.8 KB)
meino.cramer@gmx.de <meino.cramer@gmx.de> [13-01-01 12:04]:
the userspace one.
guide.
    * am33x-v3.2
    master
Best regards,
mcc
For more options, visit http://beagleboard.org/discuss
found the bug...sorry for the false alert! :slight_smile:
Best regards,
mcc
Dear mcc,
to you too!
> the userspace one.
> guide.
> * am33x-v3.2
> master
Nice. Congratulations! Could you please share your solution so others
hitting this know how to solve it too?
Paul
Paul Menzel <pm.debian@googlemail.com> [13-01-01 12:56]:
Dear mcc,
to you too!
> > the userspace one.
> > guide.
> > * am33x-v3.2
> > master
Paul
Sorry...I thought it was obvious...I didnt followed the instructions
of the guide exactly.
Unfortunately I can suspend to mem but it does not wake up...
Best regards,
mcc
Dear’ mcc
Could tell me the method of suspending the BBB?
Now,I used “Kernel 3.8.13, Angstrom filesystem”,when I type “echo mem >/sys/power/state”,it show echo failed.
What should I do?
