Problems with Realtek Driver
Hello List;
I appear to be having problems with some new hardware.
When the system boots I get the following error:
“phy0 → rt2x00lib_request_firmware: Error - Failed to request Firmware.”
Here is part of dmesg:
[ 6.098791] usb 1-1: reset high-speed USB device number 2 using musb-hdrc
[ 6.377455] ieee80211 phy0: Selected rate control algorithm ‘pid’
[ 6.378738] Registered led device: rt2800usb-phy0::radio
[ 6.378874] Registered led device: rt2800usb-phy0::assoc
[ 6.379016] Registered led device: rt2800usb-phy0::quality
[ 6.379186] usbcore: registered new interface driver rt2800usb
[ 8.647992] phy0 → rt2x00lib_request_firmware: Error - Failed to request Firmware.
[ 8.691107] phy0 → rt2x00lib_request_firmware: Error - Failed to request Firmware.
I can configure the device using iwconfig:
root@beaglebone:~# iwconfig wlan0 essid “Here Goes Nothing”
wlan0 IEEE 802.11bgn ESSID:“Here Goes Nothing”
Mode:Managed Access Point: Not-Associated Tx-Power=0 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:on
Also if I try lsmod I get:
root@beaglebone:~# lsmod
Module Size Used by
arc4 1131 2
rt2800usb 11342 0
rt2800lib 34894 1 rt2800usb
rt2x00usb 9241 1 rt2800usb
rt2x00lib 33001 3 rt2800usb,rt2800lib,rt2x00usb
mac80211 150052 3 rt2800lib,rt2x00usb,rt2x00lib
cfg80211 123019 2 rt2x00lib,mac80211
spidev 3888 0
ip_tables 7830 0
x_tables 14348 1 ip_tables
g_mass_storage 24026 0
rfcomm 24259 0
ircomm_tty 14073 0
ircomm 8407 1 ircomm_tty
irda 85557 2 ircomm_tty,ircomm
hidp 10152 0
bluetooth 109714 4 rfcomm,hidp
rfkill 14605 3 cfg80211,bluetooth
ipv6 210466 14
http://git.kernel.org/?p=linux/kernel/git/dwmw2/linux-firmware.git;a=tree
2013/2/11 William Pretty Security <bill.pretty@xplornet.com>
