I decided to make another attempt a clean dir on Mainline 5.4 I was blocked. No password . That was not there before
I guess I will take a break
Linux Kernel
This script will build the kernel, modules, device tree binaries and copy them to the deploy directory.
Mainline
Debian: Getting Started with the BeagleBone Black
This is a page about TI’s Cortex-A8 based; BeagleBone Black. Availability Boards: BeagleBone Black at Digi-K…
](Debian: Getting Started with the BeagleBone Black - Linux Guides - DigiKey TechForum - An Electronic Component and Engineering Solution Forum)
Download:
git clone https://github.com/RobertCNelson/bb-kernel
cd bb-kernel/
Hello
I’ve failed to build following those instructions twice in Mainline and twice using the TI BSP.version. the 2nd attempt of TI BSP is hung as we speak after resolving dependencies for several hours. Each attempt takes hours and the build_kernel script doesnt care you already cloned 2G of code it clones torvald.git
so I retried 4 times by running build_kernel.sh twice in both directories
The Mainline had some git branch errors today
I paid to upgrade my internet for this testing and was ready to buy a 64 bit box but am scared these instructions need a refresh and I will waste $$
what would be lovely is a 2 line like is in the instruction pasted below with something that will work for sure.
the two directories I created are both on wrong branches and dont complete a buil d
Be nice not keep downloading the 2G kernel source I know there is a rebuild.sh but I am assuming that is used after a successful build
If these instruction need I tweek I can understand I can test them. If it old and not supported a heads up would be appreciated. So I need something like this below with everything needed to build a kernel including the previous two steps as my two directories are on the wrong branches
For TI v5.4.x: Real-Time
#~/ti-linux-kernel-dev/
git checkout origin/ti-linux-rt-5.4.y -b tmp
Build:
Build:
#user@localhost:~/ti-linux-kernel-dev$
./build_kernel.s
Build:
./build_kernel.s
Build:
./build_kernel.sh
Thanks!!
Think of it as I’m validating the instructions I think having these is something good. Unfortunately my VM blew up just now.
I KNOW your adamant about not supporting VM.
So I’ll build a dedicated Debian 8 dev box.
Any hints tips lessons learned what you use be appreciated.
Have a great long weekend.
VM’s usually fail when using ‘dd’.. so MLO/u-boot.img is usually the
failure point..
I think mainline might work:
debian@beaglebone:~$ uname -r
5.13.0-rc3-bone2.2
debian@beaglebone:~$ dmesg | grep pru
[ 2.044506] remoteproc remoteproc1: 4a334000.pru is available
[ 2.045701] remoteproc remoteproc2: 4a338000.pru is available
debian@beaglebone:~$ ls /dev/remoteproc/pruss-core*
/dev/remoteproc/pruss-core0:
coredump device firmware name power recovery state subsystem uevent
/dev/remoteproc/pruss-core1:
@Mark Yoder can you test?
debian@beaglebone:/dev/remoteproc/pruss-core0$ echo “start” > state
[ 243.355728] remoteproc remoteproc1: powering up 4a334000.pru
[ 243.366533] remoteproc remoteproc1: Booting fw image
am335x-pru0-fw, size 32456
[ 243.374135] remoteproc remoteproc1: remote processor 4a334000.pru is now up
debian@beaglebone:/dev/remoteproc/pruss-core0$ echo “stop” > state
[ 296.981371] remoteproc remoteproc1: stopped remote processor 4a334000.pru
