kernel 3.8.x
Thanks for the effort for addressing this problem in advance.
The following assembler and python files concists of my code to measure frequencies on the respectiver ports P8_15 and P8_16 using PRU0. The only problem being the outout of one of those frequency measured is always fluctuatung by a large margin (does show the actual output sometimes). I agree with the fact that this code can handle frequency measurement at one ports flawlessly I have checked for overflow of memory assigned at the shared ram and I can confirm that the flaw in output is not due to the overflow.Any help would be appreseated.
Thank you.
The following code is assembler code I have been using-
.origin 0
#define PRU0_ARM_INTERRUPT 19
#define CONST_PRUCFG C4
#define CONST_PRUSHAREDRAM C28
#define PRU0_CTRL 0x22000
#define PRU1_CTRL 0x24000
#define CTPPR0 0x28
#define OWN_RAM 0x000
#define OTHER_RAM 0x020
#define SHARED_RAM 0x100
#define SECOND 200000000 // 2e8 5ns cycles
#define DELAY 200 // 0.01 s
START:
lbco r0, CONST_PRUCFG, 4, 4 // Enable OCP master port
clr r0, r0, 4
sbco r0, CONST_PRUCFG, 4, 4
mov r0, SHARED_RAM // Set C28 to point to shared RAM
mov r1, PRU0_CTRL + CTPPR0
sbbo r0, r1, 0, 4
mov r2.w0, DELAY & 0xFFFF
mov r2.w2, DELAY >> 16
WAITLO:
qbbc WAITLO, r31.t15
IGNORE: // Wait for 50 consecutive readings of 1
add r0, r0, 2 // 3 cycles per loop
qbgt IGNORE, r0, r2
WAIT1: // Continue counting while input is still 1
add r0, r0, 2
qbbs WAIT1, r31.t15
WAIT2: // Continue counting while input is 0
add r0, r0, 2
qbbc WAIT2, r31.t15 // End count when input goes to 1
sbco r0, CONST_PRUSHAREDRAM, 0, 4 // Write count to RAM
MOV R31.b0, PRU0_ARM_INTERRUPT+16 // Send notification to Host for program completion
mov r0,0
WAITLO1:
qbbc WAITLO1, r31.t14
IGNORE1: // Wait for 50 consecutive readings of 1
qbgt IGNORE1, r0, r2
WAIT3: // Continue counting while input is still 1
add r0, r0, 2
qbbs WAIT3, r31.t14
WAIT4: // Continue counting while input is 0
add r0, r0, 2
qbbc WAIT4, r31.t14 // End count when input goes to 1
sbco r0, CONST_PRUSHAREDRAM,8 , 4 // Write count to RAM
mov r0, 0
jmp IGNORE
FREQ-MSR-ASSEM.p (2.07 KB)
BI-FREQ-MSR.py (2.63 KB)
