PRU Cookbook
Announcing rev 0.1.0 of PRU Cookbook
PDF: https://github.com/beagleboard/PRUCookbook/releases/download/0.1.0/book.pdf
Live view: PRU Cookbook
Source: GitHub - MarkAYoder/PRUCookbook: This is a cookbook of the Programmable Realtime Unit on the BeagleBoard
Report issues: Issues · MarkAYoder/PRUCookbook · GitHub
Outline
A cookbook for programming the PRUs in C using remoteproc and
compiling on the Beagle
Case Studies
✓ Robotics Control Library
✓ BeagleLogic
✓ LEDscape
✓ Falcon Player
❏ MachineKit
❏ ArduPilot
Getting started
✓ Selecting a Beagle
✓ Installing the Latest OS on Your Bone
✓ Flashing a Micro SD Card
✓ Cloud9 IDE
✓ Getting Example Code
✓ Blinking an LED
Running a Program; Configuring Pins
✓ Getting Code Example Files
✓ Compiling and Running
✓ Stopping and Starting the PRU
✓ The Standard Makefile
✓ Compiling with clpru and lnkpru
✓ The Linker Command File - AM335x_PRU.cmd
✓ Loading Firmware
✓ Configuring Pins for Controlling Servos
✓ Configuring Pins for Controlling Encoders
Debugging and Benchmarking [1]
✓ Debugging via an LED
✓ dmesg –Hw
✓ prudebug - A Simple Debugger for the PRU
✓ UART
Building Blocks – Applications
✓ Memory Allocation
✓ Auto Initialization of Built in LED Triggers
✓ PWM Generator
✓ Controlling the PWM Frequency
✓ Loop Unrolling for Better Performance
✓ Making All the Pulses Start at the Same Time
✓ Adding More Channels via PRU 1
✓ Sychronziing Two PRUs
✓ Reading an Input at Regular Intervals
✓ Analog Wave Generator
✓ WS2812 (NeoPixel) driver
✓ Setting NeoPixels to Different Colors
✓ Controlling Arbitrary LEDs
✓ Controlling NeoPixels Through a Kernel Driver
✓ RGB LED Matrix - No Integrated Drivers
✓ Compiling and Inserting rpmsg_pru
Accessing More I/O [2]
✓ /boot/uEnv.txt to access P8 I/O
✓ Accessing gpio
More Performance
✓ Calling Assembly from C
✓ Returning a Value from Assembly
✓ Using the Built In Counter for Timing
✓ Xout and Xin - Transfering Between PRUs
