I have been developping something for a while now. I started on a BBB rev A, migrated to rev C and have now switched to BBG (no need for HDMI.
For the OS, I have migrated from angstrom to Debian 7, to 8, kernel 3.X to 4.4. Now I need advice on choosing a version.
I am running a bunch of code (mostly python) in user-space, some web services, external SPI, I2C and CANBus peripherals and also running code on PRU0. When I started all this, UIO_PRUSS looked like the most popular way of doing things out there byt remote-proc looked like the future so I chose it.
Everything was all when and good until I switch my base image from 2016-04-21 to the latest 2016-11-06 IOT image. I am trying to get the latest @stable@ and @standard@ version before releasing my project. (Am I justified in doing this?) Now it appears that remote proc is not enabled by default.
I had to follow the steps from Greg here: https://github.com/Greg-R/pruadc1 (ref taken from this thread: https://groups.google.com/forum/#!topic/beagleboard/tQW4ZLcncF8 )to reenable-it. Even then, my /dev/rpmsg_pru30 device file just will not be created!
here is my boot dmesg:
[ 4.785011] remoteproc1: 4a334000.pru0 is available
[ 4.785035] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 4.785045] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn’t yet guaranteed.
[ 4.785341] remoteproc1: Direct firmware load for am335x-pru0-fw failed with error -2
[ 4.785360] remoteproc1: failed to load am335x-pru0-fw
[ 4.824044] pru-rproc 4a334000.pru0: booting the PRU core manually
[ 4.824075] remoteproc1: powering up 4a334000.pru0
[ 4.824182] remoteproc1: Direct firmware load for am335x-pru0-fw failed with error -2
[ 4.824199] remoteproc1: request_firmware failed: -2
[ 4.829423] pru-rproc 4a334000.pru0: rproc_boot failed
[ 4.928466] remoteproc1: releasing 4a334000.pru0
[ 4.928634] pru-rproc: probe of 4a334000.pru0 failed with error -2
[ 4.929025] remoteproc1: 4a338000.pru1 is available
[ 4.929038] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 4.929047] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn’t yet guaranteed.
[ 4.929318] remoteproc1: Direct firmware load for am335x-pru1-fw failed with error -2
[ 4.929337] remoteproc1: failed to load am335x-pru1-fw
[ 4.939607] pru-rproc 4a338000.pru1: booting the PRU core manually
[ 4.939637] remoteproc1: powering up 4a338000.pru1
[ 4.939736] remoteproc1: Direct firmware load for am335x-pru1-fw failed with error -2
[ 4.939750] remoteproc1: request_firmware failed: -2
[ 4.944962] pru-rproc 4a338000.pru1: rproc_boot failed
[ 5.052392] remoteproc1: releasing 4a338000.pru1
[ 5.052550] pru-rproc: probe of 4a338000.pru1 failed with error -2
lsmod after boot:
Module Size Used by
spidev 8860 0
c_can_platform 7581 0
c_can 12220 1 c_can_platform
can_dev 14358 1 c_can
spi_omap2_mcspi 12952 0
pwm_tiehrpwm 5883 0
pwm_tiecap 4571 0
tieqep 9981 0
omap_aes_driver 23889 0
omap_sham 26513 0
omap_rng 5544 0
rng_core 9066 1 omap_rng
evdev 13511 1
uio_pdrv_genirq 3923 0
uio 10524 1 uio_pdrv_genirq
8021q 22979 0
garp 7049 1 8021q
mrp 8903 1 8021q
stp 2430 1 garp
llc 5903 2 stp,garp
usb_f_acm 8361 1
u_serial 13753 3 usb_f_acm
usb_f_rndis 25865 1
g_multi 6010 0
usb_f_mass_storage 49849 2 g_multi
u_ether 14413 2 usb_f_rndis,g_multi
libcomposite 53554 4 usb_f_acm,usb_f_rndis,g_multi,usb_f_mass_storage
pru_rproc 15431 0
pruss_intc 8603 1 pru_rproc
pruss 12026 1 pru_rproc
I manually load the rpmsg module with modprobe rpmsg_pru. I then see 2 new modules loaded:
rpmsg_pru 5543 0
virtio_rpmsg_bus 16076 1 rpmsg_pru
I then bind the PRU:
echo “4a334000.pru0” > /sys/bus/platform/drivers/pru-rproc/bind
dmesg shows the following:
[ 312.954382] remoteproc1: 4a334000.pru0 is available
[ 312.954444] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 312.954471] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn’t yet guaranteed.
[ 312.971682] remoteproc1: powering up 4a334000.pru0
[ 312.971775] remoteproc1: Booting fw image am335x-pru0-fw, size 86724
[ 312.972162] ti-pruss 4a300000.pruss: configured system_events = 0x1000000000000000 intr_channels = 0x00000001 host_intr = 0x00000001
[ 312.981283] remoteproc1: remote processor 4a334000.pru0 is now up
[ 312.981944] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 312.982123] remoteproc1: registered virtio0 (type 7)
[ 312.982339] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss@4a300000/pru0@4a334000 probed successfully
but still no device file!
Surely someone had that functionnality working! please share!
