The following have been created (links are here):
- Video
- Blog
- Repository
This week I’m busy with my practicals (I have one tomorrow and one on Saturday), hence I will not be actively coding. Instead,
I will be reading up on kernel module and driver implementation on Linux.
Coming up with a solid detailed design. (i.e.) what is the best way for different components of the project to interact with each other, whether it is a good idea to have sysfs, what pre-processing should be done before the BotSpeak code is sent to the PRU, how the PRU signals user process and vice versa.)
Based on point number 2, come up with an userspace interface (and it’s implementation) for the first iteration of PRU-Speak.
WEEK 3 Update (end of week 2)
What has been done
Hacked on panto’s driver
Understood the flow of control in upcalls and downcalls.
Wrote an “Hello word” program for the PRU with the new compiler.
Understood how the code on the PRU must be structured, wrote a C+PRU-Assembly code which handles upcalls/downcalls
Modified the original driver and DTS, added features of creation of dev_attr and bin_attr sysfs files.
Logic in the sysfs will trigger a downcall to the PRU
Issues
The downcall triggers the IRQ handler in the PRU quite successfully, but there is a random problem with the return value while completing the downcall.
The overlay once loaded and unloaded can’t be loaded again. [ ‘rmmod’ also fails in a few cases ]
Goals
Write driver support so that PRU, kernel can share memory.
Export this shared memory to userspace.
Make the firmware support some basic BotSpeak instructions. DIO, WAIT etc
Talk up with Chris Rodgers, take his input.
Update - End of week 6
What has been done
- Got the timer to work, tried a couple of examples to understand the peripheral better.
- Moved the wait implementation to non blocking.
- Can execute single commands from userspace while running of the script. (via sysfs)
- sysfs entry to Abort an executing script - this is used when one script is to be stopped and a new script is to be loaded.
- Figured out answers to various design problems thanks to two hangouts. Figured how to handle variables, PWM, ADC etc.
Just drew an overall design here : https://drive.google.com/file/d/0B8Pib9n32qUvMzEwdWV2aUpMbGs/
- Exported current state of the PRUSpeak VM to userspace via sysfs - tells me weather the PRU is executing a script or not or just waiting.
- Started working on an shell which Chris can test this weekend. Shell resembles - http://botspeak.org/?page_id=83 (see under step 3 )
Issues
- The timer took some time to figure out. (debugging it is hard)
- The structural design of the userspace infrastructure was a pain. spent 2 days on that - but it was very fruitful
Now I know how to go about giving a nice userspace interface.
Goals (In this particular order)
- Develop the shell which Chris can use.
- IF statements and arithmetic, bit operations.
- Support of variables. [ This will be interesting
Update - End of week 7
What has been done
- Developed a TCP (port 6060) server based shell.
- Developed a bash interface to use PRU Speak. PRU can be used now by writing to “/dev/pruspeak”
- Defined an architecture for variable use.
- Instruction set encoding - Done
- Wrote a lexer to start with compiler upgrade.
- Wrote a grammar to use in yacc
Issues
- I’m a bit behind on the Docs as I lost the doc I was writing on (Google Docs has been blocked in India). Have encoding and stuff on paper as of now.
- Finish the parser by 9th Jul (Wed)
- Finish the code generation 10th Jul (Thursday)
- Add PRU support for newly generated byte code - 11th Jul (Friday)
- Develop some sample scripts and debug code if necessary - 12 Jul (Saturday)
- Buffer day in case of any problem; otherwise Documentation. - 13 Jul (Sunday)
Now I will have 5 weeks left. General outline plan -
- Develop DIO, PWM libraries. (DTO included)
- Develop AI libraries, mechanism for return values.
- Higher level libraries for SERVO, TONE/Dimming, etc
- Develop a web interface to use PRU Speak.
- Clean scrub code. Make it easier to install etc.
(week 2, 3, 4 will include documentation process in parallel)
Update - End of week 9
What has been done
(This week had a lot of debugging work – a old code showed a few problems which I had to debug)
- Arithmetic inst support added.
- Got 64 bit inst working.
- Return values support.
- Clean userspace interface. Now everything is through Objects and modules.
- Added a shell for the new compiler framework.
- 64 bit support for single instruction. (added new kernel sysfs)
- Conditional ops work.
- Array declaration instruction.
- Array size checks.
- DTS mod to take input. (pru0_r31_14/15)
- Lot of debugging on what I had done in the previous week.
Issues
- Have to figure out “digital in” stuff, I tried out some code, don’t know why it doesn’t work though! ( Still haven’t tried too much )
- Web frontend, I’m not sure as to how Jason plans to go about it. I would need to develop a back end after discussing it with him.
- I have to figure how I will prioritize the stuff I have to do! (plus tiny bugs showing up in my way – eg. I have to treat DIO/PWM etc as special, different kind of size checking. current implementation treats every array the same, this breaks things that are working)
Goals
- PWM support
- AI support
- Global pin control.
You might want to change your Subject: line to show that
