The old UIO drivers had access to the prussdrv_map_extmem function which could be used to expose DDR3 memory to the pru, and prussdrv_get_phys_addr which could be used to communicate where the PRU should access data. This is useful when you want to transfer large amounts of data between the PRU and the ARM core. This can be seen in action here.
Is the same functionality available in the newer pru_rproc drivers? If not, what’s the best way to do about doing large transfers between the PRU and the ARM core?
There’s no such feature in the rproc driver. Note: the rproc API changes two or three times a year. That’s no stuff for productive code yet.
You can implement those functions in your code. Find the source in package am335x_pru_package in file
pru_sw/app_loader/interface/prussdrv.c
But why using rproc? uio_pruss privides what you desire.
Anyway, I’m not sure that mapped memory can fulfill you target (400Mbit/s), since all trafic is running over the OCP port. Better think about DMA transfer from fast PRU RAM (DRAM[1|2], SRAM) to ARM RAM.
Thanks TJF! It’s a shame the support for rproc is lacking. Thanks for the resources, they will be helpful.
The thought was that since the uio driver is no longer being supported it would be better to go with the rproc driver so it’s supported in the future. I’m working on a new product, so I’m trying to use the newest dependencies. At the same time, if rproc doesn’t have the right features, then it’s probably not the right thing to use.
