PSP 3.00.01.06
I am following the guide on
http://ossie.wireless.vt.edu/trac/wiki/BeagleBoard_DSPLink
It needs the kernel sources that came when bitbake was run. I don't
want to go through all that hassle
when narcissus has been so kind :slight_smile:
Can I use the PSP that came with the dm3730 dvsdk?
Has anyone here applied the RTOS patch to angstrom?
David
The PSP sources worked.
I was able to successfully compile the sample sources and run them
Resources used =
http://pixhawk.ethz.ch/wiki/tutorials/omap/dsp_toolchain
Modification worth noting = the perl script for configuration.
The argument => --comps=ponslrm
Doesn't use the CHNL module of DSPLink.
Change to --comps=ponslrmc
