pthread error at Eclipse
I include the arm-linux-gnueabihf/lib folder to the project. where is pthread library?
  1. október 27., szombat 0:51:56 UTC+2 időpontban Totti a következőt írta:
For your project, under Properties->C/C++ Build->Settings->GCC C Linker->Libraries, you have to add “pthread” to the top window [Libraries (-l)]. Just adding the header file to your source code is not sufficient.
