LimengOS
The LimengOS is based on L4Re snapshots (ver: 22.04) OS framework
LimengOS is the L4Re microkernel that develop new Device Driver Environment(DDE)
by linux-3.2.0 to build device drivers environment for Arm AM335x devices.
Develope drivers for AM335x
Power and Clock Management
Control module
Ethernet subsystem
The enhanced direct memory access (EDMA)
General-purpose memory controller (GPMC)
Mtd Nand driver
Multimedia Card (MMC)
I2c and Gpio
Implement Virtual File Systems
Ubifs filesystem
Ext4 filesystem
Implement Tcp/Ip Stack
Lwip-2.1.2
http server
wget implement
The Log On BeagleBone Black(BBB)
U-Boot SPL 2021.10-00011-g6988a04622-dirty (Nov 28 2022 - 14:47:54 +0800)
Trying to boot from MMC2
U-Boot 2021.10-00011-g6988a04622-dirty (Nov 28 2022 - 14:47:54 +0800)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
Reset Source: Global external warm reset has occurred.
Reset Source: Global warm SW reset has occurred.
RTC 32KCLK Source: External.
WDT: Started with servicing (60s timeout)
Loading Environment from EXT4... OK
Board: BeagleBone Black
BeagleBone Black:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net: eth2: ethernet@4a100000, eth3: usb_ether
Press SPACE to abort autoboot in 1 seconds
ethernet@4a100000 Waiting for PHY auto negotiation to complete. done
link up on port 0, speed 100, full duplex
Using ethernet@4a100000 device
TFTP from server 192.168.3.23; our IP address is 192.168.3.100
Filename 'bootstrap.uimage'.
Load address: 0x82000000
Loading: ################################################## 7.6 MiB
3.8 MiB/s
done
Bytes transferred = 7982708 (79ce74 hex)
## Booting kernel from Legacy Image at 82000000 ...
Image Name: L4 Image #159
Created: 2023-04-10 7:53:51 UTC
Data Size: 7982644 Bytes = 7.6 MiB
Load Address: 81000000
Entry Point: 81000000
Verifying Checksum ... OK
Loading Kernel Image
Starting kernel ...
L4 Bootstrapper
Build: #159 Mon Apr 10 15:53:49 CST 2023, 9.4.0
Scanning up to 512 MB RAM, starting at offset 32MB
Memory size is 512MB (80000000 - 9fffffff)
wget | dhcp start...
ankh | PHY: 0:00 - Link is Up<c> - 100/Full<c>
lwip | Network interface is up.
lwip | IP: 192.168.3.26
lwip | GW: 192.168.3.1
lwip | to read file :rom/L4Re.html
lwip | read file ret len = 20020
lwip | to read file :/sys/test_new_dir/new.html
lwip | md5sum = c5067d0a4cb3513312918c078af34828
lwip | socket created: 3
lwip | bound to addr: -1
lwip | listen(): 0
wget | Network interface is up.
wget | IP: 192.168.3.25
wget | MASK: 255.255.255.0
wget | GW: 192.168.3.1
wget | --1970-01-01 00:00:05-- http://mirrors.bupt.edu.cn/ubuntu-releases/20.04.6/ubuntu-20.04.6-live-server-amd64.iso.zsync
wget | Resolving mirrors.bupt.edu.cn... 211.68.71.120
wget | Connecting to mirrors.bupt.edu.cn|211.68.71.120|:80... connected.
wget | HTTP request sent, awaiting response... 200 OK
wget | Length: 2905205 (2.8M) [application/octet-stream]
wget | Saving to: `/sys/ubuntu-server-amd64.iso.zsync'
wget |
100%[======================================>] 2,905,205 640K/s in 4.5s
wget |
wget | 1970-01-01 00:00:10 (637 KB/s) - `/sys/ubuntu-server-amd64.iso.zsync' saved [2905205/2905205]
wget |
Does this line support your host or the armhf arch?
wget | 1970-01-01 00:00:10 (637 KB/s) - '/sys/ubuntu-server-amd64.iso.zsync' saved [2905205/2905205]
Anyway, keep it up. It seems like you have an OS built already!
P.S. I was thinking you were building on the amd64 server. If this is true and right, okay. Or…are you building on the BBB for an image for 64-bit arch, i.e. like aarch64?
The log from the BBB board, that image had built by L4Re microkernel OS,
I had ported am335x device drivers from linux-3.2.0 to that microkernel OS,
Plan to implement L4Re microkernel OS 's product On BBB board.
see github: https://github.com/limengOS/limengOS.git
在 2023/4/22 06:30, Seth via BeagleBoard 写道:
