Pulseaudio loopback not working on BBB
I have a Beaglebone Black running Angstrom 3.8.13 connected (through USB) to a Burr-Brown PCM2900C CODEC. I can setup loopback with alsa, but not pulseaudio. The command is accepted, but the audio isn’t looped back. The commands I’m using are:
alsaloop -C hw:1,0 –P hw1:0 –t 50000 –T 1 (which works), and
pactl load-module module-loopback source=alsa_input.usb-BurrBrown_from_Texas_Instruments_USB_AUDIO_CODEC-00-CODEC.analog-stereo sink=alsa_output.usb-BurrBrown_from_Texas_Instruments_USB_AUDIO_CODEC-00-CODEC.analog-stereo latency_msec=50 (which doesn’t work)
When I run the same pactl command on my laptop, running Fedora 19, it works fine.
I have the following modules installed on the Beaglebone:
  • pulseaudio - 2.1-r9.16
  • pulseaudio-doc - 2.1-r9.16
  • pulseaudio-lib-alsa-util - 2.1-r9.16
  • pulseaudio-lib-protocol-native - 2.1-r9.16
  • pulseaudio-module-alsa-card - 2.1-r9.16
  • pulseaudio-module-alsa-sink - 2.1-r9.16
  • pulseaudio-module-alsa-source - 2.1-r9.16
  • pulseaudio-module-always-sink - 2.1-r9.16
  • pulseaudio-module-augment-properties - 2.1-r9.16
  • pulseaudio-module-card-restore - 2.1-r9.16
  • pulseaudio-module-console-kit - 2.1-r9.16
  • pulseaudio-module-default-device-restore - 2.1-r9.16
  • pulseaudio-module-detect - 2.1-r9.16
  • pulseaudio-module-device-restore - 2.1-r9.16
  • pulseaudio-module-filter-apply - 2.1-r9.16
  • pulseaudio-module-filter-heuristics - 2.1-r9.16
  • pulseaudio-module-intended-roles - 2.1-r9.16
  • pulseaudio-module-loopback - 2.1-r9.16
  • pulseaudio-module-native-protocol-unix - 2.1-r9.16
  • pulseaudio-module-null-sink - 2.1-r9.16
  • pulseaudio-module-position-event-sounds - 2.1-r9.16
  • pulseaudio-module-rescue-streams - 2.1-r9.16
  • pulseaudio-module-role-cork - 2.1-r9.16
  • pulseaudio-module-stream-restore - 2.1-r9.16
  • pulseaudio-module-suspend-on-idle - 2.1-r9.16
  • pulseaudio-module-switch-on-port-available - 2.1-r9.16
  • pulseaudio-module-udev-detect - 2.1-r9.16
  • pulseaudio-server - 2.1-r9.16
I’d like to use pulseaudio because of the added flexibility over alsa. Can anybody tell me what’s wrong?
There’s not enough information to say for sure, but there are a couple of things to check. First, do a pactl list and see what state PulseAudio thinks its various components are in. It’s likely they’re stuck in a SUSPENDED state for some reason. I haven’t configured pulseaudio on my Bone yet, but on my Pandaboard I had to change the /etc/pulse/daemon.conf file so that it used resample-method=speex-fixed-3 instead of speex-float-3.
If those ideas don’t get you any further, try turning on more debugging information when you start up PulseAudio and give us a log dump.
Levi,
Thank you for responding.
Making resample-method=speex-fixed-3 in /etc/pulse/daemon.conf file didn’t help, still no loopback. I attached the file in case there are other questionable parameters.
The pactl list command showed that source #1 and sink #0 are ‘running’, the output is as follows:
Module #0
Argument:
Usage counter: n/a
Properties:
module.author = “Lennart Poettering”
module.description = “Automatically restore the volume/mute state of devices”
module.version = “2.1”
Module #1
Argument:
Usage counter: n/a
Properties:
module.description = “Automatically restore the volume/mute/device state of streams”
Module #2
Argument:
Usage counter: n/a
Properties:
module.description = “Automatically restore profile of cards”
Module #3
Argument:
Usage counter: n/a
Properties:
module.description = “Augment the property sets of streams with additional static information”
Module #4
Argument: device_id=“1” name=“usb-BurrBrown_from_Texas_Instruments_USB_AUDIO_CODEC-00-CODEC” card_name=“alsa_card.usb-BurrBrown_from_Texas_Instruments_USB_AUDIO_CODEC-00-CODEC” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes card_properties=“module-udev-detect.discovered=1”
Usage counter: 2
Properties:
module.description = “ALSA Card”
Module #5
Argument: device_id=“0” name=“platform-sound.13” card_name=“alsa_card.platform-sound.13” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes card_properties=“module-udev-detect.discovered=1”
Usage counter: 0
Properties:
Module #6
Argument:
Usage counter: n/a
Properties:
module.description = “Detect available audio hardware and load matching drivers”
Module #7
Argument:
Usage counter: n/a
Properties:
module.description = “Native protocol (UNIX sockets)”
Module #8
Argument:
Usage counter: n/a
Properties:
module.description = “Automatically restore the default sink and source”
Module #9
Argument:
Usage counter: n/a
Properties:
module.description = “When a sink/source is removed, try to move their streams to the default sink/source”
Module #10
Argument:
Usage counter: n/a
Properties:
module.author = “Colin Guthrie”
module.description = “Always keeps at least one sink loaded even if it’s a null one”
Module #11
Argument:
Usage counter: n/a
Properties:
module.description = “Automatically set device of streams based of intended roles of devices”
Module #12
Argument:
Usage counter: n/a
Properties:
module.description = “When a sink/source is idle for too long, suspend it”
Module #13
Argument:
Usage counter: n/a
Properties:
module.description = “Create a client for each ConsoleKit session of this user”
Module #14
Argument:
Usage counter: n/a
Properties:
module.description = “Position event sounds between L and R depending on the position on screen of the widget triggering them.”
Module #15
Argument:
Usage counter: n/a
Properties:
module.description = “Mute & cork streams with certain roles while others exist”
Module #16
Argument:
Usage counter: n/a
Properties:
module.description = “Detect when various filters are desirable”
Module #17
Argument:
Usage counter: n/a
Properties:
module.description = “Load filter sinks automatically when needed”
Module #18
Argument:
Usage counter: n/a
Properties:
Module #19
Argument: source=alsa_input.usb-BurrBrown_from_Texas_Instruments_USB_AUDIO_CODEC-00-CODEC.analog-stereo sink=alsa_output.usb-BurrBrown_from_Texas_Instruments_USB_AUDIO_CODEC-00-CODEC.analog-stereo latency_msec=50
Usage counter: n/a
Properties:
module.author = “Pierre-Louis Bossart”
module.description = “Loopback from source to sink”
Sink #0
State: RUNNING
Name: alsa_output.usb-BurrBrown_from_Texas_Instruments_USB_AUDIO_CODEC-00-CODEC.analog-stereo
Description: USB AUDIO CODEC Analog Stereo
Driver: module-alsa-card.c
Sample Specification: s16le 2ch 44100Hz
Channel Map: front-left,front-right
Owner Module: 4
Mute: no
Volume: 0: 54% 1: 54%
0: -16.00 dB 1: -16.00 dB
balance 0.00
Base Volume: 100%
0.00 dB
Monitor Source: alsa_output.usb-BurrBrown_from_Texas_Instruments_USB_AUDIO_CODEC-00-CODEC.analog-stereo.monitor
Latency: 0 usec, configured 16666 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = “16”
device.api = “alsa”
device.class = “sound”
alsa.class = “generic”
alsa.subclass = “generic-mix”
alsa.name = “USB Audio”
alsa.id = “USB Audio”
alsa.subdevice = “0”
alsa.subdevice_name = “subdevice #0
alsa.device = “0”
alsa.card = “1”
alsa.card_name = “USB AUDIO CODEC”
alsa.long_card_name = “BurrBrown from Texas Instruments USB AUDIO CODEC at usb-musb-hdrc.1.auto-1.6,”
alsa.driver_name = “snd_usb_audio”
device.bus_path = “platform-musb-hdrc.1.auto-usb-0:1.6:1.0”
sysfs.path = “/devices/ocp.2/47400000.usb/musb-hdrc.1.auto/usb1/1-1/1-1.6/1-1.6:1.0/sound/card1”
udev.id = “usb-BurrBrown_from_Texas_Instruments_USB_AUDIO_CODEC-00-CODEC”
device.bus = “usb”
device.vendor.id = “08bb”
device.vendor.name = “BurrBrown from Texas Instruments”
device.product.id = “29c0”
device.product.name = “USB AUDIO CODEC”
device.serial = “BurrBrown_from_Texas_Instruments_USB_AUDIO_CODEC”
device.string = “hw:1”
device.buffering.buffer_size = “352800”
device.buffering.fragment_size = “176400”
device.access_mode = “mmap+timer”
device.profile.name = “analog-stereo”
device.profile.description = “Analog Stereo”
device.description = “USB AUDIO CODEC Analog Stereo”
alsa.mixer_name = “USB Mixer”
alsa.components = “USB08bb:29c0”
module-udev-detect.discovered = “1”
device.icon_name = “audio-card-usb”
Ports:
analog-output: Analog Output (priority: 9900)
Active Port: analog-output
Formats:
pcm
Sink #1
State: SUSPENDED
Description: TI BeagleBone Black Analog Stereo
Sample Specification: s32le 2ch 48000Hz
Owner Module: 5
Mute: no
Volume: 0: 100% 1: 100%
0: 0.00 dB 1: 0.00 dB
balance 0.00
Base Volume: 100%
0.00 dB
Monitor Source: alsa_output.platform-sound.13.analog-stereo.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = “32”
device.api = “alsa”
alsa.name = “”
alsa.id = “HDMI nxp-hdmi-hifi-0”
alsa.device = “0”
alsa.card = “0”
alsa.card_name = “TI BeagleBone Black”
alsa.long_card_name = “TI BeagleBone Black”
device.bus_path = “platform-sound.13”
sysfs.path = “/devices/ocp.2/sound.13/sound/card0”
device.string = “hw:0”
device.buffering.buffer_size = “131072”
device.buffering.fragment_size = “8192”
device.description = “TI BeagleBone Black Analog Stereo”
device.icon_name = “audio-card”
Ports:
Formats:
pcm
Source #0
State: IDLE
Name: alsa_output.usb-BurrBrown_from_Texas_Instruments_USB_AUDIO_CODEC-00-CODEC.analog-stereo.monitor
Description: Monitor of USB AUDIO CODEC Analog Stereo
Owner Module: 4
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Monitor of Sink: alsa_output.usb-BurrBrown_from_Texas_Instruments_USB_AUDIO_CODEC-00-CODEC.analog-stereo
Latency: 0 usec, configured 2000000 usec
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = “Monitor of USB AUDIO CODEC Analog Stereo”
device.class = “monitor”
alsa.card = “1”
device.bus = “usb”
device.string = “1”
Formats:
pcm
Source #1
State: RUNNING
Name: alsa_input.usb-BurrBrown_from_Texas_Instruments_USB_AUDIO_CODEC-00-CODEC.analog-stereo
Owner Module: 4
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Monitor of Sink: n/a
Latency: 946634983247447 usec, configured 16666 usec
Properties:
device.api = “alsa”
alsa.device = “0”
alsa.card = “1”
device.bus = “usb”
Formats:
pcm
Source #2
State: SUSPENDED
Description: Monitor of TI BeagleBone Black Analog Stereo
Owner Module: 5
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Monitor of Sink: alsa_output.platform-sound.13.analog-stereo
Properties:
device.description = “Monitor of TI BeagleBone Black Analog Stereo”
alsa.card = “0”
device.string = “0”
Formats:
pcm
Sink Input #0
Driver: module-loopback.c
Owner Module: 19
Client: n/a
Sink: 0
Sample Specification: s16le 2ch 44143Hz
Format: pcm, format.sample_format = ““s16le”” format.rate = “44100” format.channels = “2” format.channel_map = ““front-left,front-right””
Mute: no
balance 0.00
Buffer Latency: 1992569 usec
Sink Latency: 0 usec
Resample method: speex-float-3
Properties:
media.name = “Loopback from USB AUDIO CODEC Analog Stereo”
media.role = “abstract”
media.icon_name = “audio-card-usb”
module-stream-restore.id = “sink-input-by-media-role:abstract”
Source Output #0
Owner Module: 19
Client: n/a
Source: 1
Mute: no
balance 0.00
Buffer Latency: 0 usec
Source Latency: 0 usec
Resample method: n/a
Properties:
media.name = “Loopback to USB AUDIO CODEC Analog Stereo”
module-stream-restore.id = “source-output-by-media-role:abstract”
Client #0
Driver: protocol-native.c
Owner Module: 7
Properties:
application.name = “GNOME Volume Control Media Keys”
native-protocol.peer = “UNIX socket client”
native-protocol.version = “26”
application.id = “org.gnome.VolumeControl”
application.icon_name = “multimedia-volume-control”
application.version = “2.32.0”
application.process.id = “508”
application.process.user = “root”
application.process.host = “beaglebone”
application.process.binary = “gnome-settings-daemon”
window.x11.display = “:0”
application.language = “C”
application.process.machine_id = “1a7682b7f5434568b514c002207bee65”
application.process.session_id = “1a7682b7f5434568b514c002207bee65-946766939.42508-1421050874”
Client #3
Owner Module: 7
Properties:
application.name = “pactl”
application.process.id = “595”
application.process.binary = “pactl”
window.x11.display = “:0.0”
Card #0
Owner Module: 4
Properties:
alsa.card = “1”
device.bus = “usb”
device.string = “1”
device.description = “USB AUDIO CODEC”
Profiles:
output:analog-mono: Analog Mono Output (sinks: 1, sources: 0, priority. 100)
output:analog-mono+input:analog-mono: Analog Mono Duplex (sinks: 1, sources: 1, priority. 101)
output:analog-mono+input:analog-stereo: Analog Mono Output + Analog Stereo Input (sinks: 1, sources: 1, priority. 160)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority. 6000)
output:analog-stereo+input:analog-mono: Analog Stereo Output + Analog Mono Input (sinks: 1, sources: 1, priority. 6001)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority. 6060)
input:analog-mono: Analog Mono Input (sinks: 0, sources: 1, priority. 1)
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority. 60)
off: Off (sinks: 0, sources: 0, priority. 0)
Active Profile: output:analog-stereo+input:analog-stereo
Ports:
Part of profile(s): output:analog-mono, output:analog-mono+input:analog-mono, output:analog-mono+input:analog-stereo, output:analog-stereo, output:analog-stereo+input:analog-mono, output:analog-stereo+input:analog-stereo
Card #1
Owner Module: 5
Properties:
alsa.card = “0”
device.string = “0”
device.description = “TI BeagleBone Black”
Profiles:
Ports:
Part of profile(s): output:analog-stereo
Thank you again for your help,
Keith
daemon.conf (2.28 KB)
Levi,
OK, the following entry lets us know Sink #0 is running, and everything looks to be in good shape there.
Notice that it has a ‘Monitor Source’, which is essentially a way to get at all the samples that have been sent to this sink and thus to its audio port. If samples were playing, we’d expect to see the monitor source active.
Sink #0
State: RUNNING
Owner Module: 4
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Properties:
device.api = “alsa”
alsa.device = “0”
alsa.card = “1”
device.bus = “usb”
Ports:
Formats:
pcm
This entry shows us the monitor source for Sink 0, but as you can see it’s currently in the IDLE state, meaning that no samples are being played out.
Source #0
State: IDLE
Owner Module: 4
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Properties:
alsa.card = “1”
device.bus = “usb”
device.string = “1”
Formats:
pcm
Here we have the actual source attached to the audio input. It’s also running, but if you look down at the latency field, you can see the first signs of the problem. It’s configured for 16666 usec of latency, but the calculated latency is MUCH higher! Still, it’s not clear from this entry why it’s so high.
Source #1
State: RUNNING
Owner Module: 4
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Properties:
device.api = “alsa”
alsa.device = “0”
alsa.card = “1”
device.bus = “usb”
Formats:
pcm
Here we’ve got the loopback module, which is what is connecting the source and sink. Everything looks fine until we get to the Buffer Latency, which is pretty high: 1992569 usec. That’s nearly 2 seconds for samples to get through the buffer! Clearly the problem is here. And two lines down, we see the reason: The resample method is still speex-float-3, and the implementation must be using soft floating point emulation somewhere.
Sink Input #0
Owner Module: 19
Client: n/a
Sink: 0
Mute: no
balance 0.00
Properties:
This is the source end of the loopback; no issues here. Apparently all the work gets done in the sink end of the loopback.
Source Output #0
Owner Module: 19
Client: n/a
Source: 1
Mute: no
balance 0.00
Properties:
So, if you look at the config file you posted, you’ll see semicolons in front of all the config directives. I know it’s screwy, but that’s actually one of the comment characters for pulseaudio’s config syntax. You changed the right line, but it was a comment before and it’s still a comment! Delete the semicolon at the front of that line and you should be in much better shape.
Levi,
Thank you very much for your thorough response, and for finding the problem with my pulseaudio config file. It was silly of me to assume that the # characters at the top of the file were the only way to comment out lines. Now that my resample method is speex-fixed-3, pulseaudio works much better, but there is a two second lag between input and output. That’s understandable due to the two second buffer latency indicated in sink input #0 (see pactl list response below), but I don’t see how that number is derived. Do you have thoughts on this?
Module #0
Argument:
Usage counter: n/a
Properties:
Module #1
Argument:
Usage counter: n/a
Properties:
Module #2
Argument:
Usage counter: n/a
Properties:
Module #3
Argument:
Usage counter: n/a
Properties:
Module #4
Usage counter: 2
Properties:
Module #5
Usage counter: 0
Properties:
Module #6
Argument:
Usage counter: n/a
Properties:
Module #7
Argument:
Usage counter: n/a
Properties:
Module #8
Argument:
Usage counter: n/a
Properties:
Module #9
Argument:
Usage counter: n/a
Properties:
Module #10
Argument:
Usage counter: n/a
Properties:
Module #11
Argument:
Usage counter: n/a
Properties:
Module #12
Argument:
Usage counter: n/a
Properties:
Module #13
Argument:
Usage counter: n/a
Properties:
Module #14
Argument:
Usage counter: n/a
Properties:
Module #15
Argument:
Usage counter: n/a
Properties:
Module #16
Argument:
Usage counter: n/a
Properties:
Module #17
Argument:
Usage counter: n/a
Properties:
Module #18
Argument:
Usage counter: n/a
Properties:
Module #19
Usage counter: n/a
Properties:
Sink #0
State: RUNNING
Owner Module: 4
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Properties:
device.api = “alsa”
alsa.device = “0”
alsa.card = “1”
alsa.long_card_name = “BurrBrown from Texas Instruments USB AUDIO CODEC at usb-musb-hdrc.1.auto-1.2,”
device.bus_path = “platform-musb-hdrc.1.auto-usb-0:1.2:1.0”
sysfs.path = “/devices/ocp.2/47400000.usb/musb-hdrc.1.auto/usb1/1-1/1-1.2/1-1.2:1.0/sound/card1”
device.bus = “usb”
Ports:
Formats:
pcm
Sink #1
State: SUSPENDED
Owner Module: 5
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Properties:
device.api = “alsa”
alsa.name = “”
alsa.device = “0”
alsa.card = “0”
Ports:
Formats:
pcm
Source #0
State: IDLE
Owner Module: 4
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Properties:
alsa.card = “1”
device.bus = “usb”
device.string = “1”
Formats:
pcm
Source #1
State: RUNNING
Owner Module: 4
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Latency: 946552791901390 usec, configured 16666 usec
Properties:
device.api = “alsa”
alsa.device = “0”
alsa.card = “1”
device.bus = “usb”
Formats:
pcm
Source #2
State: SUSPENDED
Owner Module: 5
Mute: no
balance 0.00
Base Volume: 100%
0.00 dB
Properties:
alsa.card = “0”
device.string = “0”
Formats:
pcm
Sink Input #0
Owner Module: 19
Client: n/a
Sink: 0
Sample Specification: s16le 2ch 44324Hz
Mute: no
balance 0.00
Buffer Latency: 1904904 usec
Resample method: speex-fixed-3
Properties:
Source Output #0
Owner Module: 19
Client: n/a
Source: 1
Mute: no
balance 0.00
Properties:
Client #0
Owner Module: 7
Properties:
application.process.id = “512”
application.process.session_id = “1a7682b7f5434568b514c002207bee65-946684837.201133-2106186165”
Client #3
Owner Module: 7
Properties:
application.process.id = “599”
Card #0
Owner Module: 4
Properties:
alsa.card = “1”
device.bus = “usb”
device.string = “1”
Profiles:
Ports:
Card #1
Owner Module: 5
Properties:
alsa.card = “0”
device.string = “0”
Profiles:
Ports:
Keith
Does anyone have thoughts on the two second lag on pulseaudio loopback (see my 11 November 2013) post
Thank you
