Putty serial setup with Debian Jessie
Hello all;
I have just installed Debian Jessie (8) on an x86 machine.
When I went to setup Putty as I did on my Windows Xp machine there was no way to
Set flow control to “none” my only options were XON/XOFF and CTS/RTS.
Does anyone know what is wrong here ?
Bill
“No one could make a greater mistake than he who did nothing because he could do only a little.”
“All that is necessary for the triumph of evil is that good men do nothing” Edmond Burke (1729 - 1797)
http://www.packtpub.com/building-a-home-security-system-with-beaglebone/book
http://ca.linkedin.com/pub/bill-pretty/2b/b07/602
Hello all;
I am.
But I would prefer the integration of Putty, which also has SSH.
Or I would like to, hence my other post J
Is Linux Putty different than Windows Putty?
On Windows Putty, the controls you are asking for are in
Putty Configuration/Connection/Serial/Options controlling local serial lines/Flow Control.
— Graham
Yeah.
That’s the weird thing.
I get the same flow control dropdown list, but it just has XON/XOFF or CTS/RTS as options.
There is no “none” option. Maybe I should post a screen grab ?
That is a shame. Sounds like a Putty bug, not a Linux problem.
Select CTS/RTS, Connect the CTS wire to the RTS wire, and let her rip.
Same result as “selecting none.”
— Graham
Unfortunately it is an FTDI USB adapter L
If it is the six wire version for the BBB, FTDI TTL-232R.
CTS is pin 2 is BROWN wire, RTS is pin 6 is the GREEN wire.
— Graham
You’re right !!
It’s a sparkfun board, but I can do the same thing.
Never thought of that.
Thanks J
