I’m wanting to use the BeagleBone Black to generate a FINITE number of pulses, in order to control a stepper motor. For the controller I have, an A4988, each pulse is one step on the motor. How can I use the PWM on the BBB to send, say, 5 pulses, and no more or less than 5? Or I can use a GPIO. Whichever works.
I have the Adafruit BBIO library installed. I have thought of doing this in a simple, stupid way - just using python’stime.wait()
and toggling a GPIO pin, however many times I’d like. But this seems very inaccurate, timing-wise, and moreover inelegant; is there a way to do this better? I’m also investigating events – i.e., count the numberof pulses that have occured using another GPIO, then stop the PWM when the number of pulses I want has been counted.
Any ideas?
You will need to use a GPIO pin and manually toggle it.
If you need precise speed control, you can task a PRU unit to toggle the pins with precise timing.
You could use the SPI interface
May be you can ask these guys here: http://www.halaser.eu/e1701m.php
They’re offering an industrial motor controller based on an BBB and should have solved this problem.
what is the end product you want ? cnc ? 3d printer ?
Linuxcnc does all this and is proven and reliable and works on a beaglebone black ( machinekit)
i am a moderator for Linuxcnc , and have worked with steppers for a lot of years , so give me some more information and see how it fits or not to your project needs it all depends on what else you want the BBB to do , as you only have limited resources
A4988 is a standard stepper driver and works no differently than any other ,
if Linuxcnc is too much of bruteforce etc , see Derricks video here , it works very well
http://derekmolloy.ie/beaglebone/driving-stepper-motors-in-embedded-linux-on-the-beaglebone/
Shout if i can be of help
Dave
see
Linuxcnc.org
Machinekit see
http://www.machinekit.io/
google group machinekit
