Here is the Python code. It is started once, as a service, by the web gui program and runs forever.
Its output is consumed by the web server program that started it.
P.S. As a sanity check, the original BBB has been running this same service routine (without the web interface or sensors) for 61 days and has not hung… Yet.
#!/usr/bin/python3
import iio
import time
import datetime
import math
import sys
iio_context = iio.Context()
class Am335xAdc:
def init( self, vrefp=1.8, vrefm=0.0 ):
self.vrefp = vrefp
self.vrefm = vrefm
self._device = iio_context.find_device(‘TI-am335x-adc.0.auto’)
if self._device is None:
raise RuntimeError(“ADC not enabled”);
self._channels =
self._raw =
for i in range(8):
ch = self._device.find_channel( ‘voltage%d’ % i )
self._channels.append( ch )
if ch is not None:
ch = ch.attrs[‘raw’]
self._raw.append( ch )
# output range 0 .. 4095
def raw( self, ch ):
return int( self._raw[ ch ].value )
# output range 0.0 .. 1.0
def value( self, ch ):
return self.raw( ch ) / 4095
# output range vrefm .. vrefp
def voltage( self, ch ):
return self.value( ch ) * ( self.vrefp - self.vrefm ) + self.vrefm
adc = Am335xAdc()
Thermister constants
resistance at 25 degrees C
THERMISTORNOMINAL = 10000 # temp. for nominal resistance (almost always 25 C)
TEMPERATURENOMINAL = 25
The beta coefficient of the thermistor (usually 3000-4000)
BCOEFFICIENT = 3435
the value of the ‘other’ resistor
SERIESRESISTOR = 10000
Calabration tweaks for each zone
TANK_CAL = 3.50
INLET_CAL = 3.30
OUTLET_CAL = 2.00
BTU Calculation constants
SAMPLE_RATE = 2 # Number of seconds per sample
GPM = 5.0 # Gallons per Minute Flow Rate
INTERGRAL = 2.0 # Itegration period in minutes
BTU_MULT = ((GPM/(60/SAMPLE_RATE)) * 8.33333)
Define ADC channel numbers (0-7) and associated header pin
CollectPin = 4 # P9-33
HeatPin = 6 # P9-35
RecircPin = 2 # P9-37
TankPin = 1 # P9-40
InletPin = 3 # P9-38
OutletPin = 5 # P9-36
Target_ID = “thermal_1008”
def getTemp(Sensor):
how many samples to take and average, more takes longer but is more ‘smooth’
NUMSAMPLES = 5
Temperature = 0
take N samples in a row
samples = 0
for i in range(0,NUMSAMPLES):
samples=samples + (1-adc.value(Sensor))
#print (“Sample = %d Sum = %5.0f” % (i, samples))
average all the samples out
average = samples / NUMSAMPLES
if average != 0:
# convert the value to resistance
average = 1 / average - 1
average = SERIESRESISTOR / average
# steinhart = average / THERMISTORNOMINAL # (R/Ro)
steinhart = THERMISTORNOMINAL / average # (R/Ro)
steinhart = math.log(steinhart) # ln(R/Ro)
steinhart /= BCOEFFICIENT # 1/B * ln(R/Ro)
steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15) # + (1/To)
steinhart = 1.0 / steinhart # Invert
steinhart -= 273.15 # convert to C
Temperature = ((steinhart * 9.0)/ 5.0) + 32.0 # Convert Celcius to Fahrenheit
if Sensor == TankPin:
Temperature = Temperature + TANK_CAL
if Sensor == InletPin:
Temperature = Temperature + INLET_CAL
if Sensor == OutletPin:
Temperature = Temperature + OUTLET_CAL
return Temperature
Set starting conditions
CurrTime = time.localtime()
CollectRun = False
HeatRun = False
RecircRun = False
LastSeconds = CurrTime.tm_sec
LastMinutes = CurrTime.tm_min
LastDay = CurrTime.tm_mday
Sum_BTU = 0
Sum_Inlet = 0
Sum_Outlet = 0
Sum_Delta = 0
BTU_24Hr = 0
Sum_BTU = 0
Delta_Temp = 0
SampleCount = 0
Begin endless loop (Service routine)
while 1:
Do this once every n seconds
if (CurrTime.tm_sec != LastSeconds) and ((CurrTime.tm_sec % SAMPLE_RATE) == 0):
TankTemp = getTemp(TankPin) # Read All Temperatures
InletTemp = getTemp(InletPin)
OutletTemp = getTemp(OutletPin)
CollectCur = adc.value(CollectPin) # Get status of all pumps
HeatCur = adc.value(HeatPin)
RecircCur = adc.value(RecircPin)
# Process current sensors
if CollectCur > 0.35:
CollectRun = 1
else:
CollectRun = 0
if HeatCur > 0.15:
HeatRun = 1
else:
HeatRun = 0
if RecircCur > 0.15:
RecircRun = 1
else:
RecircRun = 0
# Average measurements
Sum_Outlet += OutletTemp
Sum_Inlet += InletTemp
SampleCount += 1
# Process BTU calculations
if CollectRun:
DeltaTemp = OutletTemp - InletTemp
if DeltaTemp < 0:
DeltaTemp = 0
Sum_Delta += DeltaTemp
Sum_BTU += (BTU_MULT * DeltaTemp)
else:
DeltaTemp = 0
#print ("2-Sec BTU= %5.0f Sum_BTU = %5.0f BTU_MULT= %2.4f" % (Sum_BTU, (BTU_MULT * DeltaTemp), BTU_MULT))
# Reset Seconds Trigger
time.sleep((SAMPLE_RATE - 0.3))
Do this once each INTERGRAL minutes
if (CurrTime.tm_min != LastMinutes) and ((CurrTime.tm_min % INTERGRAL) == 0):
BTU_24Hr = BTU_24Hr + Sum_BTU
if SampleCount != 0:
DeltaAvg = Sum_Delta / SampleCount
InletAvg = Sum_Inlet / SampleCount
OutletAvg = Sum_Outlet / SampleCount
else:
DeltaAvg = 0
InletAvg = 0
OutletAvg = 0
timestamp = datetime.datetime.now().isoformat()
print ("metric:id=%s,n=TankTemperature,vd=%0.1f,u=F, ts=%s" % (Target_ID, TankTemp, timestamp))
print ("metric:id=%s,n=InletTemperature,vd=%0.1f,u=F, ts=%s" % (Target_ID, InletAvg, timestamp))
print ("metric:id=%s,n=OutletTemperature,vd=%0.1f,u=F, ts=%s" % (Target_ID, OutletAvg, timestamp))
print ("metric:id=%s,n=DeltaTemp,vd=%0.1f,u=F, ts=%s" % (Target_ID, DeltaAvg, timestamp))
print ("metric:id=%s,n=Sum_BTU,vd=%4.0f,u=BTU, ts=%s" % (Target_ID, Sum_BTU, timestamp))
print ("metric:id=%s,n=BTU_24Hr,vd=%6.0f,u=BTU, ts=%s" % (Target_ID, BTU_24Hr, timestamp))
print ("metric:id=%s,n=CollectCur,vd=%3.0f,u=W, ts=%s" % (Target_ID, (CollectCur * 171), timestamp))
print ("metric:id=%s,n=HeatCur,vd=%3.0f,u=W, ts=%s" % (Target_ID, (HeatCur * 171), timestamp))
print ("metric:id=%s,n=RecircCur,vd=%3.0f,u=W, ts=%s" % (Target_ID, (RecircCur * 171), timestamp))
sys.stdout.flush()
# Reset Intergral accumulators
Sum_BTU = 0
Sum_Delta = 0
Sum_Inlet = 0
Sum_Outlet = 0
SampleCount = 0
# Reset Minutes Trigger
Do this once each 24 hours
if (CurrTime.tm_mday != LastDay):
BTU_24Hr = 0
