i have installed angstrom on beagle board,but when i was running qt
application on beagle there are two cursors painting over them ,pls
anyone give me the solution.
Thanks..
If you start qt application with -qws parameter you probably started 2
applications and both with -qws.
If what I say is correct you only need to start the first with -qws
and the second without.
Tell me if it solved...
