Qt Embedded and PowerVR Driver
Has any one had luck getting the PowerVR driver working qith QT 4.5.0
and OpenEmbedded?
I added " -plugin-gfx-powervr -opengl es2" to the qt4-embedded_4.5.0.bb
When I boot the image I run "export QWS_DISPLAY=powervr"
Then when I run my app i get the following output
powervr: driver not found
Aborted
Some advice would be greatly appreciated.
and OpenEmbedded?
Aborted
Sorry I have no experience with powervr driver so these may sound
dumb but I say anyway.
Have you installed the driver plugin into the qt plugin folder?
Is your application loading the plugin? AFAIK, you need to load
plugins when you need them.
Caglar
the plugin exists in /usr/lib/qtopia/plugins/gfxdrivers/
Also my understand of the plugins were that they were loaded as the
QWS and you didn't have to call them out specifically in your code.
Not to rain on your parade, but I talked to the Trolltech (well, Nokia nowadays) developers and they say using the SGX for 2d stuff is sloooooow. Anything that isn't like quake3 will be slow on the sgx :frowning:
regards,
Koen
If I am using vector graphics in QT shouldn't the OpenGLES
capabilities give me a boost? Not that I would be able to know one
way or the other since the problem still exists that it will not let
me use the powervr driver (whether it is slow or not).
It would be approx 2-4 times slower than using the cpu.
regards,
Koen
Besides OpenVG implementation on OMAP is buggy like crazy.
What if you are wanting to do alpha transparency? Will that be slower
than using the CPU?
Notice: This e-mail is intended solely for use of the individual or entity to which it is addressed and may contain information that is proprietary, privileged, company confidential and/or exempt from disclosure under applicable law. If the reader is not the intended recipient or agent responsible for delivering the message to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If this communication has been transmitted from a U.S. location it may also contain data subject to the International Traffic in Arms Regulations or U.S. Export Administration Regulations and cannot be disseminated, distributed or copied to foreign nationals, residing in the U.S. or abroad, without the prior approval of the U.S. Department of State or appropriate export licensing authority. If you have received this communication in error, please notify the sender by reply e-mail or collect telephone call and del
ete or destroy all copies of this e-mail message, any physical copies made of this e-mail message and/or any file attachment(s).
You do know that your email notice forbids you from posting to this list?
Its great if you have been told that it would be that slow but since
that was not my original question, I would still like to know why the
driver won't load.
