Did anyone managed to compile Qt (any version) with SGX working?
I tried million combinations. Not a single one worked.
There are 100s of "solutions" on internet. Not a single one is
working.
I have this installed:
Ubuntu Oneiric
Kernel v3.0.8-x3 (known that is working with sgx)
SGX installed using create_sgx_package.sh and following procedure.
SGX demos are working perfectly.
Compiled Qt 4.6 using same headers and libraries as given by
To compile used patch which adds support for arm target and command ./
configure_omap3
Edited /etc/powervr.ini:
[default]
WindowSystem=libpvrQWSWSEGL.so
Executed:
sudo /etc/init.d/pvr restart
I run:
export QT_DEBUG__PLUGINS=1
./hellogl_es2 -qws -diplay powervr > ~/work/debug.txt 2>&1
After execution:
Green area in helogl_es2 instead of animation. I need to reboot to
restore display on HDMI. Minicom access is working.
Content of debug.txt:
QFactoryLoader::QFactoryLoader() looking at "/opt/qt-embedded/plugins/
gfxdrivers/
libqgfxpvregl.so"
keys
("powervr")
mousedrivers/
libqpcmousedriver.so"
keys ("Auto", "IntelliMouse", "Microsoft", "MouseSystems",
"MouseMan")
Cannot open input device '/dev/tty0': Permission
denied
QEglContext::createSurface(): Unable to create EGL surface, error =
0x300b
QGLContext::makeCurrent(): Cannot make invalid context
current
0x300b
iconengines/
libqsvgicon.so"
keys ("svg", "svgz",
"svg.gz")
Even tried to use patch for 4.6 which should help with error 0x300b.
No success
Any idea about solving this?
I'm willing to accept solution which uses any version of Ubuntu, Qt or
GX drivers
