Brent
May 31, 2013, 1:33pm
1
I just tried to install qt4-embedded on the BBB, and I received the following error:
Collected errors:
satisfy_dependencies_for: Cannot satisfy the following dependencies for qt4-embedded:
kernel-image-3.2.30 *
opkg_install_cmd: Cannot install package qt4-embedded.
Is there a simple configuration somewhere that can be changed to allow it to work on 3.8 kernels? Or do I need to build Qt myself?
Yeah, make 3D SGX work with 3.8 You should be able to install it with --force-depends, it will work, just without opengl-es.
Brent
May 31, 2013, 4:01pm
3
Yep, that worked. Thanks!
Brent
May 31, 2013, 6:16pm
4
By the way… are there any plans to add Qt5 support in the near future?
Opkg install qt4-embedded --force-depends
-brent
Brent
June 5, 2013, 8:28pm
6
Standard version that came with the BBB.
can u post the procedure how do u run the QT app in Beagle Bone Black.?
jfyive
September 23, 2013, 7:21am
8
so how do we get opengl-es api on BBB?
when we use the -force-depends command what exactly is going on? Are we forcing the install despite the needed dependencies??
Thank you for the help!!
Well even with “force-depends” you end with iconv errors about fonts
I am using Angstrom YOCTO project 3.8 Kernal.
Kindly help me out a bit on this.
Stucked for about a week and couldn’t get qt4 Embedded running on bbb.
opkg install qt4-embedded --force-depends isnt working at all…Same problem persists.
