I am facing below problem in running quake2.
I have built the rootfs for beagle board with quake2 package.
Please tell if any other steps need to be taken.
Should the Linux kernel need dsp support for quake to run ?
Robin
root@beagleboard:/usr/bin# ./quake2
Quake 2 -- Version 3.21+r0.16
Debug
using /home/root/.quake2/baseq2/ for
writing
couldn't exec
default.cfg
couldn't exec
config.cfg
Console
initialized.
I am also facing the same problem. I downloaded quake2 package from
opkg install command. I tried installing quake3 but it seems to fail
due to a dependency package not being available in the repo. What are
the correct repos for opkg? I am also noticing that package feed
browser on angstrom website doesn't match the list of packages in
opkg. Is it because of wrong default repos?
