Querries from IIT Kharagpur
Dear Sir/Madam
We are looking for Beagle Boards for a research project at IIT Kharagpur.
We have few queries regarding the board BeagleBone Black
  1. It has 7 analog pins. Are those pins multiplexed? or it can acquire data from 7 channels simultaneously.
  2. Do you have any supported DAC and ADC module for this board?
Please contact @8388906976 for any further queries.
Dear Sir/Madam
These are multiplexed pins. Maximum sample rate that can be expected would of the order of 100k Sa/s
  1. Do you have any supported DAC and ADC module for this board?
You can connect and sample an external ADC using the onboard Programmable Real-Time Units (PRUs) , if internal ADC does not satisfy your requirements.
For DAC, depending on the requirements, PWM outputs may be lowpass filtered to create an analog signal.
Regards
Abhishek
