For Ubuntu 12.10, Kernel:3.8.5-bone11,
Any pointers as to where the userspace mux sysfs entry is located on
3.8 kernel now.
On 3.2 kernel equivalent is here:
/sys/kernel/debug/omap_mux/
regards
randy
3.8 kernel now.
regards
randy
3.8 kernel now.On 3.2 kernel equivalent is here:
/sys/kernel/debug/pinctrl/44e10800.pinmux
But, it isn't writable, so you'll need to use devicetree overlays.
pinmux-helper and capemgr are there to help do that on-the-fly without
having to install another driver to make the pinctrl calls. Here's an
example:
/sys/kernel/debug/omap_mux//sys/kernel/debug/pinctrl/44e10800.pinmux
example:validation-scripts/test-capemgr at master · jadonk/validation-scripts · GitHub
Thanks will give it a try today.
Thanks again.
Wow so much going on to just change a pin mux.
Something looks over engineered to me here.
Looks i might be better off to just do a raw register write to mux
registers after mmap to userspace. Will that work?
Something looks over engineered to me here.Looks i might be better off to just do a raw register write to mux
Nope.
As far as I know, the kernel won't let you write to those registers
after mmap()ing them. There is this attempt to get the kernel to
manage the pinmuxes through the pinctrl API. It is in a rather
frustrating stage of development.
registers after mmap to userspace. Will that work?Nope.
Registers like GPIO are mmap'd and work well.
Any reason why mux control register behave differently then?
Any particular reason?
Looks things are still in preliminary state then.
Jason
I am able to mmap() the mux register base address.
From userspace i can also read the value.
ptr = mmap(NULL, 0x1FFF, flags, MAP_SHARED, m_fd, 0x44E10000);
Read of *ptr returns correct value for any valid register for pin mux.
But *ptr = 0 is not able to write to reflect a zero.
Any reason why this does not work?
Thats what i did if u look at this thread:
"3.8 kernel: support legacy pin mux"
