I am kind of new to this all. Sorry to be asking so many
novice questions here, I would really appreciate if someone could drop
pointers or guide me. I would be happy to study it. I was reading the
following link:
Q1. Within the first few lines, the article shows a "Partition
Layout", where and how do these get defined ? Do we do it in the
Xloader ?
Q2. Is this Partition layout for a flash part internal to the OMAP or
is it an external flash part which sits on the BeagleBoard ?
Q3. In either of the cases, are these flash parts, Raw flash or
Managed flash ?
Q4. Is my understanding correct, when I say that a filesystem like
"ext3, VFAT etc" may live on a "Managed Flash" but not on "Raw
Flash" ? Raw Flash would use something specific like "jffs". Is my
understanding correct ?
following link:
Q1. Within the first few lines, the article shows a “Partition
Layout”, where and how do these get defined ? Do we do it in the
Xloader ?
Usually with NAND flash the partition layout is merely a contractual thing, there is no partition table anywhere on the flash. There are two options that are often used:
Partition table is defined in U-boot and it passes it to kernel via command line (mtdparts=…)
Partition table is built into the kernel. Usually into the board file.
The example on that page seems to have option #2.
“cmdlinepart partition parsing not available”
OMAP has no internal flash. So it is for the external part.
Managed flash ?
RAW. The article you refers talks about RAW NAND.
“ext3, VFAT etc” may live on a “Managed Flash” but not on “Raw
Flash” ? Raw Flash would use something specific like “jffs”. Is my
Correct.
(e)MMC would qualify as managed flash for example.
> Hello,
> following link:
> Xloader ?
1. Partition table is defined in U-boot and it passes it to kernel via
command line (mtdparts=...)
2. Partition table is built into the kernel. Usually into the board file.
"cmdlinepart partition parsing not available"
How does the xloader have knowledge of very to jump to, incase it does
not have a partition table ?
Also, Suppose I want another "mtd" partition, other than the ones that
are already listed, how can I add a new MTD partition ? Say for
example I want one MTD partition to be "jffs" and another to be
"yaffs" ?
