Questions on Image Builder
I had a hard time finding a Debian Jessie console image (.img file) for both BB-X15 and BBB. I eventually found that here, https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Debian_Build_Instructions/ , but it seemed like LXQT images were more readily available.
But if we needed a console image, it seemed like there were two options (1) do sudo apt-get remove on unnecessary packages or (2) use image builder.
Regarding option 2, Image Builder.
  1. Is Image Builder for everybody to use or mainly for Robert to generate BeagleBone/BeagleBoard images? I saw an earlier thread (circa 2014) where Robert indicated that it was created mainly for him to use to generate images and referred to it as a “frankenscript.”
  2. Can Image Builder now run on a host Linux machine with the Linaro toolchain, for instance, or is it still intended to be run on an Armhf device?
This wiki from 2015 says build on ARMHF: https://elinux.org/BeagleBoneBlack_Rebuild_Debian_Image_Using_image-builder,
“QEMU is un-reliable, thus no longer supported… Spend some Money and buy a real ARMHF device to run this script.”
  1. Is the procedure for generating images in image builder still as per https://elinux.org/BeagleBoneBlack_Rebuild_Debian_Image_Using_image-builder or is there an updated wiki now?
Thanks!!
Jeff
Like here?
Section 6.1.4.2
https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#microSD.2FStandalone:.28console.29.28BeagleBoard-X15.29
Yeah... it's a long list, i'd entertain ideas for how to better show that..
1) Is Image Builder for everybody to use or mainly for Robert to generate
images and referred to it as a "frankenscript."
Yeah you can use it.. Just make sure to run it on arm..
./RootStock-NG.sh -c bb.org-debian-jessie-console-v4.4
Generates:
https://rcn-ee.net/rootfs/bb.org/testing/2017-10-02/console/debian-8.9-console-armhf-2017-10-02.tar.xz
and:
sudo ./setup_sdcard.sh --img-1gb
bbx15-debian-8.9-console-armhf-2017-10-02 --dtb am57xx-beagle-x15
--rootfs_label rootfs --hostname BeagleBoard-X15
Generates:
https://rcn-ee.net/rootfs/bb.org/testing/2017-10-02/console/bbx15-debian-8.9-console-armhf-2017-10-02-1gb.img.xz
2) Can Image Builder now run on a host Linux machine with the Linaro
device?
"QEMU is un-reliable, thus no longer supported... Spend some Money and buy a
real ARMHF device to run this script."
If your goal is to fix QEMU, and your getting paid lots of money to do
it.. The script is a great "test" script to find broken things in
QEMU...
3) Is the procedure for generating images in image builder still as per
I just run this every week:
Thing is with all the images, there's really not "one" script...
I've split it into multiple "builds"...
http://gfnd.rcn-ee.org:8080/view/bb.org-jessie/
http://gfnd.rcn-ee.org:8080/view/bb.org-stretch/
https://github.com/RobertCNelson/omap-image-builder/blob/master/publish/rcn-ee_bb.org-stable.sh
Thanks Robert!!
Yeah, I guess those images were kind of right under my nose, but images/builds/build instructions are in so many different locations, sometimes it’s hard to know where the best place to look is and what the best practices are. (I know, you’re probably tired of hearing that excuse…)
One other potential compelling case for going to image builder (or building everything from source if you know how to do that) is the tags go back way before Jessie (maybe even before Toy Story existed?). So at some point, when Jessie falls off of the list in https://elinux.org/Beagleboard:BeagleBoneBlack_Debian, looks like you can still get back to a Jessie image through image builder. Is this a reasonable assumption?
Cheers,
Jeff
Thanks Robert!!
sometimes it's hard to know where the best place to look is and what the
best practices are. (I know, you're probably tired of hearing that
excuse..)
Some users just watch:
My current plan is to continue building Jessie snapshots once a month
(usually around the 1st) till the build breaks.
In the past (Looking at our Wheezy images) this breakage was caused by
nodejs, in our case with Jessie, we have nodejs v4.x installed, so we
should be good till April 2018:
https://github.com/nodejs/Release#release-schedule1
On Thu, 5 Oct 2017 08:52:05 -0500, Robert Nelson
<robertcnelson@gmail.com> declaimed the
following:
  Oh good -- something for April Fools Day <G>
That's also Easter Sunday.. So yeah, I'll be busy so no images on that
day anyways.. :wink:
