We all same to be having the same trouble L
I tried the same pin as you, with the same results WTF ??
Check out the “opkg fails” thread. You have to edit the .conf files for opkg to get it to work.
Here is what you do:
Goto: /etc/opkg and change all of conf files so the address starts with www. instead of feed.
Then run “opkg update, etc”
It worked for me.
