Helllo!
I’m having problem connecting my beaglebone black using the usb cable to my laptop after i chnage the uEnv txt file?
How do i solve it?
Best Regards,
SHAOMIN
Helllo!
How do i solve it?
Best Regards,
SHAOMIN
Change it back...
If you have a usb-serial adapter cable you could debug it.
If you can't get access... reflash...
Helllo,
May i know how to reflash it?
Because i try pluck my beaglebone black with my usb cable, it don’t detect it anymore.
http://beagleboard.org/latest-images
http://elinux.org/Beagleboard:Updating_The_Software#Flashing_the_eMMC
Thank you for your answer!
One more question to ask you.
I connect my BeagleBone to my windows laptop and i run putty the cmd which is
root@beaglebone: apperar
after which i retrieve the sensor value using the code which is :
for sensor in /sys/bus/i2c/devices/i2c-1//_input; do echo -n "$(basename $sensor): "; cat $sensor; done
the value I retrieve is
lux1_input: 121
humidity1_input: 58476
temp1_input: 25297
pressure0_input: 99590
temp0_input: 250
How do I save this in a text file on my windows laptop instead?
No one has really answered this question. As there is NOT one answer..
It's trivial.
Pick a transfer protocol, "any" protocol.
Then make it work.
Darn, i give up on finding cobol examples..
Just fire up apache2, copy file to /var/www/ and download with your
webbrowswer..
easy peasy...
Hmmm, i did try this code
for sensor in /sys/bus/i2c/devices/i2c-1//_input; do echo -n "$(basename $sensor): "; cat $sensor; done > C:\Users\student.CNG-HP640-03\Desktop\SensorData\Sensor.txt
it didn’t have any error but it doesn’t update my txt file.
Humm... Do you see why that didn't work?
Unless you "mount" "C:\Users\student.CNG-HP640-03\Desktop\SensorData\"
on your BBB, that ">" just aint going to work.
I'm sorry, you should at-least take a Computer Science 101 course.
Good Luck,
